[petsc-users] -ksp_diagonal_scale
Fri Dec 23 13:27:26 CST 2011
On Fri, Dec 23, 2011 at 12:52, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> I am scaling my systems when dealing with small (microscopic) scales
> in SI dimensions.
The best choice is to choose suitable units so that the system is
intrinsically well-scaled.
> This is because otherwise I have very small (near
> epsilon) entries in the matrix and the solution fails or takes
> significantly longer to converge. I used to do it by hand so far, if
> there is a way to do it in Petsc - especially automatically detecting
> the optimal scale - I am all ears.
You are best off doing it by hand, it is better to avoid
-ksp_diagonal_scale when it's reasonable to do so. If you have trouble
determining a reasonable scale at assembly time, it might make sense to use.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111223/5f420f7a/attachment.htm>
