[petsc-users] KSP diverging
Fri Dec 23 07:43:54 CST 2011
On Thu, Dec 22, 2011 at 7:51 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Dec 22, 2011 at 19:46, Matthew Knepley <knepley at gmail.com> wrote:
>> dtol failure is impossible for GMRES (and CG). Consider checking with
>> that.
> Well, if you turn of restarts in GMRES and if orthogonalization is working
> correctly.
Even if you lose orthogonality, it will just stagnate since you always have
the solution
from the first few vectors. Likewise, I do not see how you can get an
diverging sequence
from restarting since you always have the last residual, you just stagnate.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111223/db66d7ba/attachment.htm>
