[petsc-users] KSP diverging
Thu Dec 22 19:46:45 CST 2011
On Thu, Dec 22, 2011 at 7:37 PM, Mohamad M. Nasr-Azadani
<mmnasr at gmail.com>wrote:
> Thanks so much Jed for your prompt response. I will start experimenting
> with all the suggestions.
dtol failure is impossible for GMRES (and CG). Consider checking with that.
   Matt
> Best,
> Mohamad
> On Thu, Dec 22, 2011 at 5:31 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Thu, Dec 22, 2011 at 19:20, Mohamad M. Nasr-Azadani <mmnasr at gmail.com>wrote:
>>> Any hints on what is happening here or how I could narrow it down?
>> I would start by following the general advice in the FAQ
>> http://www.mcs.anl.gov/petsc/documentation/faq.html#kspdiverged
>>> I know that we had an early discussion on the convergnce for the
>>> incompressible CFD problems and boomerAMG preconditioning,
>> That was about solving the coupled system. That shouldn't be an issue for
>> the Poisson problem.
>>> but it seems that for this case, that is the only one that does not blow
>>> up for most of the time integration I have.
>> Since this problem only occurs after long time integration, you might
>> consider writing out the model state when you see divergence so that you
>> can experiment with alternative methods quickly.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111222/1e7a82da/attachment.htm>
