[petsc-users] parallel PCASM
Reza Madankan rm93 at buffalo.edu
Wed Dec 21 14:12:21 CST 2011
Hello,
I am trying to parallelize the ASM preconditioner while solving a linear
system. For more detail, I have printed relevant parts of code in the
following:
*static char help[]="Reading in a matrix\n";*
* #include<stdio.h>*
* #include<math.h>*
* #include<stdlib.h>*
* #include "petscvec.h" /* This enables us to use vectors. */*
* #include "petscmat.h" /* This enables us to use Matrices. It includes the*
* petscvec header file*/*
* #include "petscksp.h" /* Now we can solve linear systems. Solvers used are
* KSP. */*
* extern PetscErrorCode MyKSPMonitor(KSP,PetscInt,PetscReal,void*);*
* int main(int argc, char **argv)*
* /* Declaration of Matrix A and some vectors x*/*
* Vec  w, ypcq, mean_tmp, x, PzyTvec;*
* Mat Ym, Y, Mean, Ypcq, YpcqT, Pzz, InnProd, Para, Pzy, PzyT,PzzT,K, KT,
PK, PzzTMP, Pmat, XYmat, KY;*
* FILE *fp, *fp1, *fp2, *fp3;*
* PetscInt index,i,j,k, ns=16, nw=100, tindex_f=120, col,tind, mz, nz, its;*
*printf("Enter number of sensors (ns):\n");*
*scanf("%d",&ns);*
*printf("Enter number of time steps (tindex_f):\n");*
*scanf("%d",&tindex_f);*
* PetscMPIInt size;*
* PC pc;*
* KSP ksp;*
* PetscReal norm, tol=1.e-14;*
* PetscBool nonzeroguess = PETSC_FALSE;*
* PetscViewer mviewer;*
* PetscScalar scalar,rhsy[ns*tindex_f*nw],rhsym[ns*tindex_f], rhsw[nw],
Ymat[tindex_f*ns][nw], tmp, rhsp[2*nw], xvec[ns*tindex_f], pmat[4],
xymat[2], rnorm;*
* PetscErrorCode ierr;*
* /* This part is needed for the help flag supplied at run-time*/*
* ierr = PetscInitialize(&argc,&argv,(char*)0,help);CHKERRQ(ierr);*
* ierr = MPI_Comm_size(PETSC_COMM_WORLD, &size);CHKERRQ(ierr);*
* //if (size != 1) SETERRQ(PETSC_COMM_WORLD,1,"This is a uniprocessor
example");*
*PetscPrintf(PETSC_COMM_WORLD,"size is: %D\n",size);*
*int nstindex_f=ns*tindex_f;*
*ierr =
PetscOptionsGetInt(PETSC_NULL,"-n",&nstindex_f,PETSC_NULL);CHKERRQ(ierr);*
*// Solution for K:*
*    ierr =
*    ierr =
PetscOptionsGetBool(PETSC_NULL,"-nonzero_guess",&nonzeroguess,PETSC_NULL);
CHKERRQ(ierr);*
*// KSPMonitorSet(ksp,MyKSPMonitor,PETSC_NULL,0);*
*    ierr = VecCreate(PETSC_COMM_WORLD,&x);CHKERRQ(ierr);*
*    ierr = PetscObjectSetName((PetscObject) x, "Solution");CHKERRQ(ierr);*
*    ierr = VecSetSizes(x,PETSC_DECIDE,ns*tindex_f);CHKERRQ(ierr);*
*    ierr = VecSetFromOptions(x);CHKERRQ(ierr);*
*    ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);*
*// ierr = KSPMonitorSet(ksp,PetscInt n,PetscReal rnorm, void *); *
*// ierr = monitor(ksp,Int it,PetscReal rnorm,);*
*    ierr = MatTranspose(Pzz,MAT_INITIAL_MATRIX,&PzzT);*
*    MatAssemblyBegin(PzzT,MAT_FINAL_ASSEMBLY);*
*    MatAssemblyEnd(PzzT,MAT_FINAL_ASSEMBLY);*
*    ierr =
KSPSetOperators(ksp,PzzT,PzzT,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);*
*    ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);*
*    ierr = PCSetType(pc,PCASM);CHKERRQ(ierr);*
*    ierr =
KSPSetTolerances(ksp,1e-6,PETSC_DEFAULT,PETSC_DEFAULT,1e+9);CHKERRQ(ierr);*
*    ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);*
*    if (nonzeroguess)*
*         PetscScalar p = 0.5;*
*         ierr = VecSet(x,p);CHKERRQ(ierr);*
*         ierr = KSPSetInitialGuessNonzero(ksp,PETSC_TRUE);CHKERRQ(ierr);*
*    ierr = MatTranspose(Pzy,MAT_INITIAL_MATRIX,&PzyT);*
*    MatAssemblyBegin(PzyT,MAT_FINAL_ASSEMBLY);*
*    MatAssemblyEnd(PzyT,MAT_FINAL_ASSEMBLY);*
*    ierr = MatCreate(PETSC_COMM_WORLD,&KT);CHKERRQ(ierr);*
*    ierr =
MatSetSizes(KT,PETSC_DECIDE,PETSC_DECIDE,ns*tindex_f,2);CHKERRQ(ierr);*
*    ierr = MatSetFromOptions(KT);CHKERRQ(ierr);*
*    int ctr=0;*
*    for (ctr=0; ctr<2; ctr++)*
*    ierr = VecCreate(PETSC_COMM_WORLD,&PzyTvec);*
*    ierr = VecSetSizes(PzyTvec,PETSC_DECIDE,ns*tindex_f);*
*    ierr = VecSetFromOptions(PzyTvec);*
*    ierr = MatGetColumnVector(PzyT,PzyTvec,ctr);*
*    ierr = KSPSolve(ksp,PzyTvec,x);CHKERRQ(ierr);*
*    ierr = KSPGetIterationNumber(ksp,&its);CHKERRQ(ierr);*
*       ierr = KSPGetResidualNorm(ksp,& norm);    *
*    printf("residual norm is=%e\n",norm);*
*      printf("iteration number is=%d\n",its);*
*    ierr = KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);*
*// printf("%d\n", ctr);*
*    for (i=0; i<ns*tindex_f; i++)*
*    ierr = VecGetValues(x,1,&i,&xvec[i]);*
*    ierr = MatSetValues(KT,1,&i,1,&ctr,&xvec[i],INSERT_VALUES);*
*    MatAssemblyBegin(KT,MAT_FINAL_ASSEMBLY);*
*    MatAssemblyEnd(KT,MAT_FINAL_ASSEMBLY);*
*    MatTranspose(KT,MAT_INITIAL_MATRIX,&K);*
*    MatAssemblyBegin(K,MAT_FINAL_ASSEMBLY);*
*    MatAssemblyEnd(K,MAT_FINAL_ASSEMBLY);*
*    MatPtAP(Pzz,KT,MAT_INITIAL_MATRIX,1.0,&PK);*
*//MatCopy(Pzz,PzzTMP,SAME_NONZERO_PATTERN);*
*           ierr = MatAXPY(Pmat,-1,PK,DIFFERENT_NONZERO_PATTERN);*
*    MatView(Pmat,PETSC_VIEWER_STDOUT_WORLD);*
*           ierr = MatAXPY(Ym,-1,Mean,DIFFERENT_NONZERO_PATTERN);*
*    MatAssemblyBegin(Ym,MAT_FINAL_ASSEMBLY);*
*           MatAssemblyEnd(Ym,MAT_FINAL_ASSEMBLY);*
*    ierr = MatMatMult(K,Ym,MAT_INITIAL_MATRIX,PETSC_DEFAULT,&KY);*
*    ierr = MatAssemblyBegin(KY,MAT_FINAL_ASSEMBLY);*
*    ierr = MatAssemblyEnd(KY,MAT_FINAL_ASSEMBLY);*
*       ierr = MatAXPY(XYmat,1,KY,DIFFERENT_NONZERO_PATTERN);*
*    MatView(XYmat,PETSC_VIEWER_STDOUT_WORLD);*
*ierr = MatDestroy(&Mean);*
*ierr=PetscFinalize();CHKERRQ(ierr);*
* return 0;*
I am using the following commands to compile and run the code:
*mpicc pcasm.c -o pcasm -l petsc*
*mpiexec -np 2 ./pcasm*
But when I run the code I get the following error message which I don't
know what it means.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Floating point exception!
[0]PETSC ERROR: Infinite or not-a-number generated in norm!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 3, Fri Sep 30 10:28:33
CDT 2011
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./pcasm on a linux-imp named k07n14.ccr.buffalo.edu by rm93
Wed Dec 21 15:05:33 2011
[0]PETSC ERROR: Libraries linked from
/util/petsc/petsc-3.2-p3/linux-impi-mkl/lib
[0]PETSC ERROR: Configure run at Fri Oct 21 08:36:23 2011
[0]PETSC ERROR: Configure options --CC=/util/intel/impi/
4.0.3.008/intel64/bin/mpiicc --FC=/util/intel/impi/
4.0.3.008/intel64/bin/mpiifort --CXX=/util/intel/impi/
4.0.3.008/intel64/bin/mpiicpc--with-blas-lapack-dir=/util/intel/composer_xe_2011_sp1/mkl/lib/intel64
--download-hypre=1 --with-debugging=0 -PETSC_ARCH=linux-impi-mkl
--with-shared-libraries=1
[0]PETSC ERROR:
[0]PETSC ERROR: VecNorm() line 167 in src/vec/vec/interface/rvector.c
[0]PETSC ERROR: VecNormalize() line 261 in src/vec/vec/interface/rvector.c
[0]PETSC ERROR: GMREScycle() line 128 in src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: KSPSolve_GMRES() line 231 in src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: KSPSolve() line 423 in src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: main() line 487 in "unknowndirectory/"pcasm.c
application called MPI_Abort(MPI_COMM_WORLD, 72) - process 0
rank 0 in job 2  k07n14.ccr.buffalo.edu_51735   caused collective abort of
all ranks
  exit status of rank 0: return code 72
Could anyone help me on this problem? Thanks in advance for any help.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111221/4620679a/attachment.htm>
