[petsc-users] mumps freezes for bigger problems
Hong Zhang hzhang at mcs.anl.gov
Wed Dec 21 09:15:29 CST 2011
Direct solvers often require large memory for storing matrix factors.
As Jed suggests, you may try superlu_dist.
With mumps, I notice you use parallel analysis, which is relative new in mumps.
What happens if you use default sequential analysis with
different matrix orderings?
I usually use matrix ordering '-mat_mumps_icntl_7 2'.
Also, you can increase fill ratio,
-mat_mumps_icntl_14 <20>: ICNTL(14): percentage of estimated workspace
increase (None)
i.e., default ration is 20, you may try 50? (I notice that you already use 30).
It seems you use 16 CPUs for "a mere couple thousands
elements" problems, and mumps "silently freezes". I do not have this type
of experience with mumps. I usually can solve sparse matrix of size
10k with 1 cpu using mumps.
When mumps runs out of memory or gets other problems, it terminates
execution and dumps out error message,
not freezes.
Something is wrong here. Use a debugger and figuring out where it freezes.
Hong
On Wed, Dec 21, 2011 at 7:01 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> -pc_type lu -pc_factor_mat_solver_package superlu_dist
> On Dec 21, 2011 6:19 AM, "Dominik Szczerba" <dominik at itis.ethz.ch> wrote:
>> I am successfully solving my indefinite systems with MUMPS but only
>> for very small problems. To give a feeling, a mere couple thousands
>> elements. If I only double the problem size, it silently freezes, even
>> with max verbosity via the control parameters. Did anyone succeed here
>> with big problems? Any recommendations for a drop-in replacement for
>> MUMPS?
>> Thanks for any hints,
>> Dominik
>> Options used:
>> -mat_mumps_icntl_4 3 -mat_mumps_icntl_28 2 -mat_mumps_icntl_29
>> Output:
>> ****** FACTORIZATION STEP ********
>>  GLOBAL STATISTICS PRIOR NUMERICAL FACTORIZATION ...
>>  NUMBER OF WORKING PROCESSES              =          16
>>  OUT-OF-CORE OPTION (ICNTL(22))           =           0
>>  REAL SPACE FOR FACTORS                   =  1438970073
>>  INTEGER SPACE FOR FACTORS                =    11376442
>>  MAXIMUM FRONTAL SIZE (ESTIMATED)         =       16868
>>  NUMBER OF NODES IN THE TREE              =       43676
>>  Convergence error after scaling for ONE-NORM (option 7/8)   = 0.21D+01
>>  Maximum effective relaxed size of S              =   231932340
>>  Average effective relaxed size of S              =   182366303
>>  REDISTRIB: TOTAL DATA LOCAL/SENT         =     1509215    22859750
>>  GLOBAL TIME FOR MATRIX DISTRIBUTION       =      0.8270
>>  ** Memory relaxation parameter ( ICNTL(14)  )            :        35
>>  ** Rank of processor needing largest memory in facto     :         0
>>  ** Space in MBYTES used by this processor for facto      :      2017
>>  ** Avg. Space in MBYTES per working proc during facto    :      1618
