[petsc-users] Mat-view-draw Colors, Views
Mon Dec 19 18:30:27 CST 2011
On Mon, 19 Dec 2011, Jonathan Backs wrote:
> Hi,
> I am trying to troubleshoot my Jacobian using the command-line option -mat_view_draw. In the X-window that pops up, the non-zero structure is shown using three colors: cyan, blue, and red. What do these three colors represent?
red : positive value
bule: negative value
cyan: zero value [thats entered with matsetvalues]
> When I add the option -draw_pause -1, I am given three chances to right-click on the X-window for each Jacobian evaluation. Each time, a different view of the Jacobian is shown, though the first two views look the same. What do these different views show?
left mouse: zoom-in
middle mouse: zoom-out
right-mouse: continue the program
So if you click the right-mouse - then the program continues - and
what you see next is the 'next' matrix thats assembled in your
program. It could be a factor matrix or something thats created in the
preconditioner. This depends on the path your code takes.
Satish
> Thank you for your time,
> Jonathan
