[petsc-users] Pseudoinverse of a large matrix
Chetan Jhurani chetan.jhurani at gmail.com
Mon Dec 19 13:38:34 CST 2011
> It can be further optimized using the Woodbury identity for two cases -
> rank <= size or rank >= size to reduce the size of auxiliary internal Cholesky solve.
Sorry, that's wrong.  I meant rank <= size/2 or rank >= size/2.  Size here
refers to square matrix size, but this analysis can be done for rectangular
case too.
Chetan
From: Chetan Jhurani [mailto:chetan.jhurani at gmail.com]
Sent: Monday, December 19, 2011 11:35 AM
To: 'PETSc users list'
Subject: RE: [petsc-users] Pseudoinverse of a large matrix
Couple of optimizations not there currently.
1.   It can be changed to use sparse RRQR factorization for sparse input matrix.
2.   It can be further optimized using the Woodbury identity for two cases -
Chetan
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Modhurita Mitra
Sent: Monday, December 19, 2011 11:01 AM
To: PETSc users list
Subject: Re: [petsc-users] Pseudoinverse of a large matrix
I am trying to express the radiation pattern of an antenna in terms of spherical harmonic basis functions. I have radiation pattern
data at N=324360 points. Therefore, my matrix is spherical harmonic basis functions evaluated till order sqrt(N) (which makes up at
total of N elements), evaluated at N data points. So this is a linear least squares problem, and I have been trying to solve it by
finding its pseudoinverse which uses SVD. The elements of the matrix are complex, and the matrix is non-sparse. I have solved it in
MATLAB using a subsample of the data, but MATLAB runs out of memory while calculating the SVD at input matrix size 2500 X 2500. I
need to solve this problem using the entire data.
I was thinking of using SLEPc because I found a ready-to-use code which computes the SVD of a complex-valued matrix (
http://www.grycap.upv.es/slepc/documentation/current/src/svd/examples/tutorials/ex14.c.html ). I don't know how to use either PETSc
or SLEPc (or Elemental) yet, so I am trying to figure out where to start and what I should learn.
Modhurita
On Mon, Dec 19, 2011 at 12:31 PM, Matthew Knepley <knepley at gmail.com> wrote:
On Mon, Dec 19, 2011 at 12:21 PM, Modhurita Mitra <modhurita at gmail.com> wrote:
I have to compute the pseudoinverse of a 324360 X 324360 matrix. Can PETSc compute the SVD of this matrix without parallelization?
If parallelization is needed, do I need to use SLEPc?
With enough memory, yes. However, I am not sure you want to wait. I am not sure how SLEPc would help here.
>From the very very little detail you have given, you would need parallel linear algebra, like Elemental. However,
I would start out from a more fundamental viewpoint. Such as replacing "compute the psuedoinverse" with
"solve a least-squares problem" if that is indeed the case.
   Matt
Modhurita
What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to
which their experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111219/245bcd5c/attachment.htm>
