[petsc-users] PetscPrintf
Tue Dec 13 10:24:37 CST 2011
On Tue, Dec 13, 2011 at 10:19 AM, Xiangdong Liang <xdliang at gmail.com> wrote:
> On Tue, Dec 13, 2011 at 11:14 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Tue, Dec 13, 2011 at 10:13 AM, Xiangdong Liang <xdliang at gmail.com>
> wrote:
> >> Hello everyone,
> >> I am using PetscPrintf(PETSC_COMM_WORLD,.....) to print out some
> >> information. When I run the program on multiple processors, some of
> >> these calls are printed out multiple times, while other calls are
> >> printed out once. Should it be printed only once if I use
> >> PETSC_COMM_WORLD? Thanks.
> > The print is executed only on rank 0 of the communicator provided.
> I agree. This implies that the message can be printed out at most
> once. Do you have any hints why I saw the message printed out multiple
> times? Thanks.
Maybe
1) You have a bug in your code
2) You ran with the wrong mpiexec, so it just ran 2 copies
  Matt
> Xiangdong
> >    Matt
> >> Xiangdong
> >> PS. I am using petsc-dev. My code works fine on real petsc-3.1-p8. I
> >> just switched to complex petsc-dev and see this problem.
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111213/05d30efe/attachment.htm>
