[petsc-users] petsc-users Digest, Vol 36, Issue 46
Tue Dec 13 09:03:22 CST 2011
On Tue, Dec 13, 2011 at 8:59 AM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
> Hi Thomas,
> That wasn't quite Matt's question, since MPI_Init gets called regardless
> of whether you use mpiexec.  He wants to know if your code breaks if
> MPI_Init() is called, in which case we can blame this on your MPI
> implementation and not PETSc :)
Alternatively, configure PETSc using --with-mpi=0 and check.
PETSc really has no way of intercepting output or changing buffering, but
MPI does.
   Matt
> -A
> On Tue, Dec 13, 2011 at 5:55 PM, Thomas Leissing <thomas.leissing at cstb.fr>wrote:
>> > This sounds like MPI rather than PETSc, since it plays with output.
>> Are you
>> > running with mpiexec?
>> >   Matt
>> Yes I do. I have the same results with and without mpiexec.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111213/aaca3116/attachment.htm>
