[petsc-users] debugging with no X11 available
Mon Dec 12 06:46:43 CST 2011
On Mon, Dec 12, 2011 at 2:48 AM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> Hi,
> I am debugging my code on a system that does not allow any X11
> connections, therefore the following does not work:
> mpiexec -n 2 solver run.xml -start_in_debugger -display :0.0
> Are there alternative ways of using a debugger circumventing X11
> connections?
No. You can usually set the DISPLAY correctly for the backend machine.
Consult the admin.
   Matt
> Thanks
> Dominik
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111212/a4aedbbf/attachment.htm>
