[petsc-users] zeros in sparse aij
Xiangdong Liang xdliang at gmail.com
Fri Dec 9 18:15:43 CST 2011
If I use MAT_IGNORE_ZERO_ENTRIES option, is it possible that I still
see some zeros in the sparse matrix? In my problem, when I use this
ignore_zero options, the number of nonzeros is significantly reduced
(from mat_view_info) but still larger than the number of nonzeros
counting from matlab. When I use mat_view_draw, I see some light green
lines (corresponding to zeros). I am wondering where these zeros come
from? Thanks
Xiangdong
On Wed, Dec 7, 2011 at 12:15 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 7 Dec 2011, Satish Balay wrote:
>> As indicated call "MatSetOption(A,MAT_IGNORE_ZERO_ENTRIES,PETSC_TRUE)
>> - before any calls to MatSetValue/s()
>> And verify with MatView()
> Ok - here is what you can see with a slightly modified mat/examples/tests/ex38.c
> Notice "C[0,1] = 0.0" and thats not visible anymore with
> MatSetOption(MAT_IGNORE_ZERO_ENTRIES)
> Satish
> asterix:/home/balay/spetsc/src/mat/examples/tests>cat ex38.c
> static char help[] = "Tests MatSetValues().\n\n";
> #include <petscmat.h>
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc,char **args)
>  Mat            C;
>  PetscInt       i,n = 5,midx[3],nidx[2];
>  PetscErrorCode ierr;
>  PetscBool      flg;
>  PetscScalar    v[6];
>  PetscInitialize(&argc,&args,(char *)0,help);
>  ierr = MatCreate(PETSC_COMM_WORLD,&C);CHKERRQ(ierr);
>  ierr = MatSetSizes(C,PETSC_DECIDE,PETSC_DECIDE,n,n);CHKERRQ(ierr);
>  ierr = MatSetFromOptions(C);CHKERRQ(ierr);
>  ierr = PetscOptionsHasName(PETSC_NULL,"-ignore_zero_entries",&flg);CHKERRQ(ierr);
>  if (flg) {  ierr = MatSetOption(C,MAT_IGNORE_ZERO_ENTRIES,PETSC_TRUE);CHKERRQ(ierr);}
>  for (i=0; i<6; i++) v[i] = (PetscReal)i;
>  midx[0] = 0; midx[1] = 2; midx[2] = 3;
>  nidx[0] = 1; nidx[1] = 3;
>  ierr = MatSetValues(C,3,midx,2,nidx,v,ADD_VALUES);CHKERRQ(ierr);
>  ierr = MatAssemblyBegin(C,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>  ierr = MatAssemblyEnd(C,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>  ierr = MatView(C,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>  ierr = MatDestroy(&C);CHKERRQ(ierr);
>  ierr = PetscFinalize();
>  return 0;
> asterix:/home/balay/spetsc/src/mat/examples/tests>./ex38 -mat_view_info
> Matrix Object: 1 MPI processes
>  type: seqaij
>  rows=5, cols=5
>  total: nonzeros=6, allocated nonzeros=25
>  total number of mallocs used during MatSetValues calls =0
>    using I-node routines: found 4 nodes, limit used is 5
>  type: seqaij
> row 0: (1, 0)  (3, 1)
> row 1:
> row 2: (1, 2)  (3, 3)
> row 3: (1, 4)  (3, 5)
> row 4:
> asterix:/home/balay/spetsc/src/mat/examples/tests>./ex38 -mat_view_info -ignore_zero_entries
>  type: seqaij
>  rows=5, cols=5
>  total: nonzeros=5, allocated nonzeros=25
>  type: seqaij
> row 0: (3, 1)
> row 1:
> row 4:
