[petsc-users] Metis building
Alexander Grayver agrayver at gfz-potsdam.de
Fri Dec 9 04:51:42 CST 2011
Hello,
It's pretty weird situation now. A couple of weeks ago I configured
petsc-3.2-p5 successfully, today I decided to do it with new options and
it didn't work, I tried to do it with old options just to check and got
error:
lib/petsc-3.2-p5> ./configure --with-petsc-arch=intel-complex-debug-f-ds
--with-fortran-interfaces=1 --download-superlu_dist --download-mumps
--download-parmetis --download-metis
--with-scalapack-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_scalapack_lp64.a
--with-scalapack-include=/opt/intel/Compiler/11.1/072/mkl/include
--with-blacs-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_blacs_openmpi_lp64.a
--with-blacs-include=/opt/intel/Compiler/11.1/072/mkl/include
--with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex
--with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
--with-precision=double --with-x=0
              Configuring PETSc to compile on your system
***** WARNING: CC found in enviornment variables - ignoring
***** WARNING: CXX found in enviornment variables - ignoring
***** WARNING: FC found in enviornment variables - ignoring
***** WARNING: F77 found in enviornment variables - ignoring
***** WARNING: F90 found in enviornment variables - ignoring
Compiling & installing Metis; this may take several
minutes
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
Error running make on Metis: Could not execute "cd
/home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3 && make clean &&
make library && make minstall && make clean":
(cd Lib ; make clean )
make[1]: Entering directory
`/home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3/Lib'
rm -f *.o
make[1]: Leaving directory
(cd Programs ; make clean )
`/home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3/Programs'
rm -f *.o
(cd Test ; make clean )
`/home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3/Test'
rm -f *.o
make: *** No rule to make target `library'.  Stop.
I looked into /home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3/makefile:
default:
     (cd Lib ; make )
     (cd Programs ; make )
     (cd Test ; make )
clean:
realclean:
     (cd Lib ; make realclean )
     (cd Programs ; make realclean )
     (cd Test ; make realclean )
So there is no library.
I have no idea what went wrong. Any suggestions would be appreciated.
Thanks in advance.
Alexander
