[petsc-users] mat_view_info and the number of matrix objects
Xiangdong Liang xdliang at gmail.com
Wed Dec 7 22:41:19 CST 2011
Hello everyone,
I am using mat_view_info to see the matrix information in ksp/ksp/ex2.c:
http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex2.c.html
When I use single processor, I see two matrix-objects. One is the
operator A, but what's the other one? It seems that the other one
(always in seqaij or seqsbaij format) is from KSPSolve. What's the
purpose of that matrix object?
If I try two processors, I see five matrix-objects (more confused).
Can you help me understand where these "five" matrices come from?
Thanks.
Best,
Xiangdong
Here is the script:
 ./ex2 -mat_view_info
Matrix Object: 1 MPI processes
  type: seqaij
  rows=56, cols=56
  total: nonzeros=250, allocated nonzeros=280
  total number of mallocs used during MatSetValues calls =0
    not using I-node routines
  type: seqsbaij
  rows=56, cols=56
  package used to perform factorization: petsc
  total: nonzeros=153, allocated nonzeros=153
      block size is 1
Norm of error 0.000156044 iterations 6
mpirun -np 2 ./ex2 -mat_view_info
Matrix Object: 2 MPI processes
  type: mpiaij
  rows=56, cols=56
  total: nonzeros=250, allocated nonzeros=560
    not using I-node (on process 0) routines
  type: seqaij
  rows=28, cols=28
  total: nonzeros=118, allocated nonzeros=118
  type: seqsbaij
  rows=28, cols=28
  total: nonzeros=73, allocated nonzeros=73
      block size is 1
  type: seqaij
  rows=28, cols=28
  type: seqsbaij
  rows=28, cols=28
      block size is 1
Norm of error 0.000411674 iterations 7
