[petsc-users] MATBDIAG in > 3.1
Wed Dec 7 03:36:55 CST 2011
On Wed, Dec 7, 2011 at 2:54 AM, Parker, Andrew (UK Filton) <
Andrew.Parker2 at baesystems.com> wrote:
> Legends, nice one!
> Got to that point in the souce code yesterday, saw that 7 was missing
> from the switch statement, and got worried.
> Is there any symmetry between the code in block size 5->6->7->8?  I've
> asked that without looking, so could be stupid question.  The reason I
> ask is that if there is this is a classic use of something like
> boost-preprocessor macros or a bit of templating, as in the compiler
> would expand it all out given a pattern at compile time?  Just
> interest....
This is the kind of thing you could do with templates. However, that would
mean
  1) It only works in C++, and the logic is convoluted
  2) You can't see the generated code
  3) Its impossible to debug (and usually optimize)
We are looking at other approaches.
    Matt
> Cheers again,
> Andy
> -----Original Message-----
> From: petsc-users-bounces at mcs.anl.gov
> [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: 06 December 2011 19:31
> To: PETSc users list
> Subject: Re: [petsc-users] MATBDIAG in > 3.1
>                    *** WARNING ***
>  This message has originated outside your organisation,
>  either from an external partner or the Global Internet.
>      Keep this in mind if you answer this message.
> On Tue, 6 Dec 2011, Matthew Knepley wrote:
> > On Tue, Dec 6, 2011 at 7:43 AM, Parker, Andrew (UK Filton) <
> > > So having got petsc 3.2 install and all its deps, I now get
> > > this....****
> > > [0]PETSC ERROR: PCSetUp_PBJacobi() line 207 in
> > > src/ksp/pc/impls/pbjacobi/pbjacobi.c not supported for block size
> > > 7****
> > > Any thoughts?
> > Sorry about that. There was confusion on our end. I have added the
> > code you need to 3.2. It will go out with the next patch release.
> > Alternatively, you can retrieve the source tarball from the repository
> > site or use the repository directly.
> I'm attaching this change as a patchfile - which can be applied to the
> current
> petsc-3.2 sources you have.
> cd petsc-3.2
> patch -Np1 < bpjacobi.patch
> Satish
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender.
> You should not copy it or use it for any purpose nor disclose or
> distribute its contents to any other person.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111207/afdd4d6b/attachment.htm>
