[petsc-users] MUMPS solver crash with petsc-3.2
Gong Ding gdiso at ustc.edu
Wed Dec 7 00:48:09 CST 2011
With a small matrix, mumps of AIX reports that
Entering DMUMPS driver with JOB, N, NZ =   1          25            105
 DMUMPS 4.10.0
L U Solver for unsymmetric matrices
Type of parallelism: Working host
 ****** ANALYSIS STEP ********
 Resetting candidate strategy to 0 because NSLAVES=1
Entering analysis phase with ...
                N         NZ         LIW       INFO(1)
               25        105         287             0
Matrix entries:    IRN()   ICN()
           1      1           1      2           1      3
           2      1           2      2           2      4
           2      5           3      1           3      3
           3      4           3      6           4      2
           4      3           4      4           4      7
           4      8           5      2           5      5
           5      7           5      9           6      3
           6      6           6      8           6     10
           7      4           7      5           7      7
           7     11           7     12           8      4
           8      6           8      8           8     12
           8     13           9      5           9      9
           9     11           9     14          10      6
          10     10          10     13          10     15
          11      7          11      9          11     11
          11     16          11     17          12      7
          12      8          12     12          12     17
          12     18          13      8          13     10
          13     13          13     18          13     19
          14      9          14     14          14     16
          15     10          15     15          15     19
          16     11          16     14          16     16
          16     20          17     11          17     12
          17     17          17     20          17     21
          18     12          18     13          18     18
          18     21          18     22          19     13
          19     15          19     19          19     22
          20     16          20     17          20     20
          20     23          21     17          21     18
          21     21          21     23          21     24
          22     18          22     19          22     22
          22     24          23     20          23     21
          23     23          23     25          24     21
          24     22          24     24          24     25
          25     23          25     24          25     25
 ... Structural symmetry (in percent)=  100
 Density: NBdense, Average, Median   =    0    3    3
 ... No column permutation
 Ordering based on AMF
IKEEP(.,1)=    14    16    15    17    18    24    13     9    11     5
                25    19    23    10     4    12     8     7     6    22
                21    20     3     2     1
IKEEP(.,2)=     1     1     1     1     1     1     1     1     1     1
                 1     1     1     1     1     1     2     7     0     0
                 0     0     0     0     0
IKEEP(.,3)=     0     1     1     0     1     1     0     0     0     0
                 1     1     0     0     1     1     4     5     0     1
                 1     3     4     2     5
PTRAR(.,1)=    14    16    15    17    17    18    13     9    11     5
                18    18    18    10     4    12     8     7     6    18
                18    18     3     2     1
PTRAR(.,2)=     0     0     0     0     0     0     0     0     0     0
                 0     0     0     0     0     0     0     0     0     0
                 0     0     0     0     0
PTRAR(.,3)=     3     4     4     3     4     4     5     5     5     3
                 4     4     5     3     4     4     7     7     0     1
                 1     1     0     0     0
NFSIZ(.)  =     3     4     4     7     0     0     5     5     4     4
                 0     7     0     3     3     4     5     5     4     0
                 0     0     4     4     3
FILS (.)  =     0    -3    -1     5    -8    11     0     0   -14   -15
               -23    22     6     0     0    -9     0     0   -10    13
                20    21   -24   -25     0
FRERE(.)  =    -3    -4    -2   -12    26    26     2    16   -16   -19
                26     0    26    -9   -10     7     4    17    18    26
                26    26    19   -23   -24
ERROR: 0031-250  task 0: Segmentation fault
The output is exactly the same as on linux, except the error.
On Linux, the naxt line is
Leaving analysis phase with  ...
INFOG(1)                                       =               0
INFOG(2)                                       =               0
 -- (20) Number of entries in factors (estim.) =             185
 --  (3) Storage of factors  (REAL, estimated) =             185
 --  (4) Storage of factors  (INT , estimated) =             372
 --  (5) Maximum frontal size      (estimated) =               7
 --  (6) Number of nodes in the tree           =              18
 -- (32) Type of analysis effectively used     =               1
 --  (7) Ordering option effectively used      =               2
ICNTL(6) Maximum transversal option            =               0
ICNTL(7) Pivot order option                    =               7
Percentage of memory relaxation (effective)    =              20
Number of level 2 nodes                        =               0
Number of split nodes                          =               0
I compiled petsc-dev with debug , however, my code failed with
[0] PetscCommDuplicate(): Using internal PETSc communicator 0 5
[0] PetscCommDuplicate(): Duplicating a communicator 1 6 max tags = 1073741823
The assert subroutine failed: context >= _min_context, file
/project/sprelhya/build/rhyas002a/src/ppe/poe/include/mpi_cc_inlines.h, line 314
Any suggestion?
> '-mat_mumps_icntl_4 4' which will display mumps info
> Use a debugger to see where the program terminates.
> Hong
> On Tue, Dec 6, 2011 at 10:54 PM, Gong Ding <gdiso at ustc.edu> wrote:
> > I can only analysis the core file at present.
> > It reported
> > Program terminated with signal 11, Segmentation fault.
> > #0  0x000000010217319c in dmumps_462 ()
> > Run program with -info, the output is
> > Entering DMUMPS driver with JOB, N, NZ =   1          49            217
> >  DMUMPS 4.10.0
> > Program terminated with signal SIGSEGV, Segmentation fault.
> > The example in src/ksp/ksp/examples/tests/ex3 run ok -- it solves a small
> > linear problem.
> > Also, if I reduce the matrix size to ~20x20, no crash happen.
> > I'll try to provide more information.
> > On Tue, Dec 6, 2011 at 12:52 AM, Gong Ding <gdiso at ustc.edu> wrote:
> >> Bad news.
> >> MUMPS still crash on AIX/PPC.
> >> I tried petsc-3.1, 3.2 and dev. All of them crash with ERROR: 0031-250
> >> task 0: Segmentation fault.
> >> I guess the interface of petsc-mumps has some problem, i.e. alignment.
> > Please get a stack trace with the debugger.
> >    Matt
> >>> Yes, petsc-dev works. Please merge the update to petsc-3.2.
> >> Parmetis 4.0 was released after PETSc 3.2 so it will not be updated to
> >> work with it. In general, software projects don't update a previous release
> >> on a dependent package update. Please use petsc-dev or wait until PETSc 3.3.
> > What most experimenters take for granted before they begin their experiments
> > is infinitely more interesting than any results to which their experiments
> > lead.
> > -- Norbert Wiener
