[petsc-users] MATBDIAG in > 3.1
Parker, Andrew (UK Filton) Andrew.Parker2 at baesystems.com
Tue Dec 6 07:43:03 CST 2011
So having got petsc 3.2 install and all its deps, I now get this….
[0]PETSC ERROR: PCSetUp_PBJacobi() line 207 in src/ksp/pc/impls/pbjacobi/pbjacobi.c not supported for block size 7
Any thoughts?
Cheers,
Andy
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Jed Brown
Sent: 02 December 2011 12:42
To: PETSc users list
Subject: Re: [petsc-users] MATBDIAG in > 3.1
                    *** WARNING ***
  This message has originated outside your organisation,
  either from an external partner or the Global Internet.
      Keep this in mind if you answer this message.
On Fri, Dec 2, 2011 at 06:40, Parker, Andrew (UK Filton) <Andrew.Parker2 at baesystems.com> wrote:
[0]PETSC ERROR: MatInvertBlockDiagonal_SeqBAIJ() line 129 in
src/mat/impls/baij/seq/baij.c not supported for block size 7
This was fixed in petsc-3.2
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender.
You should not copy it or use it for any purpose nor disclose or
distribute its contents to any other person.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111206/c03aaa93/attachment.htm>
