[petsc-users] Mat_CheckInode
Debao Shao Debao.Shao at brion.com
Mon Dec 5 08:46:47 CST 2011
DA,
1, Will check_inode affect the runtime performance? For example, in my case, there are such different logs:
     [0] Mat_CheckInode(): Found 18602 nodes out of 18609 rows. Not using Inode routines
     [0] Mat_CheckInode(): Found 0 nodes of 0. Limit used: 5. Using Inode routines
     [0] Mat_CheckInode(): Found 14020 nodes out of 14020 rows. Not using Inode routines
2, Here is the log_summary, looks like PCSetup is big time-consuming function, the method I'm using is ILU(1) & GMRES, may I improve it?
     MatMult            30733 1.0 8.9553e+01 1.0 3.41e+10 1.0 0.0e+00 0.0e+00 0.0e+00  2  4  0  0  0   2  4  0  0  0   380
     MatMultAdd          9552 1.0 6.6610e+00 1.0 2.42e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   363
     MatSolve           36236 1.0 2.4699e+02 1.0 9.44e+10 1.0 0.0e+00 0.0e+00 0.0e+00  6 10  0  0  0   6 10  0  0  0   382
     MatLUFactorNum      2838 1.0 2.4328e+03 1.0 7.65e+11 1.0 0.0e+00 0.0e+00 0.0e+00 61 85  0  0  0  61 85  0  0  0   315
     MatILUFactorSym      173 1.0 1.3486e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
     MatAssemblyBegin    5787 1.0 2.0547e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
     MatAssemblyEnd      5787 1.0 5.3559e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
     KSPGMRESOrthog     30679 1.0 5.5968e+00 1.0 4.06e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   725
     KSPSetup            2838 1.0 1.8219e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
     KSPSolve            5503 1.0 2.9136e+03 1.0 8.99e+11 1.0 0.0e+00 0.0e+00 0.0e+00 73100  0  0  0  73100  0  0  0   308
     PCSetUp             2838 1.0 2.5682e+03 1.0 7.65e+11 1.0 0.0e+00 0.0e+00 0.0e+00 64 85  0  0  0  64 85  0  0  0   298
     PCApply            36236 1.0 2.4709e+02 1.0 9.44e+10 1.0 0.0e+00 0.0e+00 0.0e+00  6 10  0  0  0   6 10  0  0  0   382
The matrix size is around 50000*50000, nnz is ~2000000
3, Will the fill of ilu affect the runtime performance?
     [0] MatILUFactorSymbolic_SeqAIJ(): Reallocs 0 Fill ratio:given 1 needed 1.11111
     [0] MatILUFactorSymbolic_SeqAIJ(): Reallocs 1 Fill ratio:given 1 needed 5.05
     [0] MatILUFactorSymbolic_SeqAIJ(): Reallocs 1 Fill ratio:given 1 needed 8.3410
How to set a proper value for fill, >8?
Debao
-- The information contained in this communication and any attachments is confidential and may be privileged, and is for the sole use of the intended recipient(s). Any unauthorized review, use, disclosure or distribution is prohibited. Unless explicitly stated otherwise in the body of this communication or the attachment thereto (if any), the information is provided on an AS-IS basis without any express or implied warranties or liabilities. To the extent you are relying on this information, you are doing so at your own risk. If you are not the intended recipient, please notify the sender immediately by replying to this message and destroy all copies of this message and any attachments. ASML is neither liable for the proper and complete transmission of the information contained in this communication, nor for any delay in its receipt.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111205/67c5138a/attachment-0001.htm>
