[petsc-users] KSP with MatNullSpace
Shiyuan gshy2014 at gmail.com
Fri Dec 2 22:57:14 CST 2011
I notice that when the vector indicating the nullspace is not very accurate
(norm(A*phi) very small but not zero), KSP (CG) will return
KSP_INDEFINITE_PC. When b is very close to zero in AX=b, KSP (CG) has the
same error. Is it controlled by some tolerance? How can I set the
tolerance?  Thanks.
Shiyuan
On Wed, Nov 23, 2011 at 5:00 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Nov 23, 2011, at 1:31 PM, Shiyuan wrote:
> > I've check it in Matlab. the matrix A is symmetric and has no negative
> eigenvalues( only a zero eigen value). I've also checked that the nullspace
> is correct(  norm(A*phi)<1e-11);
>    Hmm. You can run with -ksp_view_binary and email to
> petsc-maint at mcs.anl.gov the resulting file called binaryoutput.
>   Barry
> > Thanks.
> > On Wed, Nov 23, 2011 at 1:26 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Print out the matrix for a small grid then check in Matlab that it is
> symmetric and has no negative eigenvalues.
> >   Barry
> > On Nov 23, 2011, at 9:50 AM, Shiyuan wrote:
> > > Hi,
> > >     I want to solve a singular system with a known nullspace. However,
> I the KSP solve diverges with KSP_INDEFINTE_PC even if I disable the
> preconditioning by PCNONE.
> > > this is how I setup the system. What did I do wrong? Any possible
> causes? Thanks.
>  ierr=MatNullSpaceCreate(PETSC_COMM_SELF,PETSC_FALSE,1,&phi,&nsp);CHKERRV(ierr);
> > >   ierr=KSPCreate(PETSC_COMM_SELF,&ksp);CHKERRV(ierr);
> ierr=KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);CHKERRV(ierr);
> > >   ierr=KSPSetNullSpace(ksp,nsp);CHKERRV(ierr);
> > >   ierr=KSPSetType(ksp,KSPCG);CHKERRV(ierr);
> > >   ierr=KSPGetPC(ksp,&prec);CHKERRV(ierr);
> > >   ierr=PCSetType(prec,PCNONE);CHKERRV(ierr);
> > >   ierr=KSPSetTolerances(ksp,1e-5,1e-20,1e5,10000);CHKERRV(ierr);
> > >   ierr=KSPSetFromOptions(ksp);CHKERRV(ierr);
> > >   ierr=KSPSetUp(ksp);CHKERRV(ierr);
> > > Shiyuan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111202/5316350e/attachment-0001.htm>
