[petsc-users] newbie question on the parallel allocation of matrices
Fri Dec 2 09:32:00 CST 2011
On Fri, Dec 2, 2011 at 9:25 AM, Treue, Frederik <frtr at risoe.dtu.dk> wrote:
> *From:* petsc-users-bounces at mcs.anl.gov [mailto:
> petsc-users-bounces at mcs.anl.gov] *On Behalf Of *Matthew Knepley
> *Sent:* Friday, December 02, 2011 4:01 PM
> *To:* PETSc users list
> *Subject:* Re: [petsc-users] newbie question on the parallel allocation
> of matrices****
> On Fri, Dec 2, 2011 at 8:58 AM, Treue, Frederik <frtr at risoe.dtu.dk> wrote:
> petsc-users-bounces at mcs.anl.gov] *On Behalf Of *Jed Brown
> *Sent:* Friday, December 02, 2011 1:32 PM
> of matrices****
> On Fri, Dec 2, 2011 at 03:32, Treue, Frederik <frtr at risoe.dtu.dk> wrote:**
> OK, but that example seems to assume that you wish to connect only one
> matrix (the Jacobian) to a DA – I wish to specify many and I think I found
> this done in ksp ex39, is that example doing anything deprecated or will
> that work for me, e.g. with the various basic mat routines (matmult,
> matAXPY etc.) in a multiprocessor setup?****
> What do you mean by wanting many matrices? How do you want to use them? There
> is DMCreateMatrix() (misnamed DMGetMatrix() in petsc-3.2), which you can
> use as many times as you want.`****
> And this was the one I needed. However I have another question: What does
> DMDA_BOUNDARY_GHOSTED do, compared to DMDA_BOUNDARY_PERIODIC? From
> experience I now know that the PERIODIC option automagically does the right
> thing when I’m defining matrices so I can simply specify the same stencil
> at all points. Does DMDA_BOUNDARY_GHOSTED do something similar? And if so,
> how is it controlled, ie. How do I specify if I’ve got Neumann or Dirichlet
> conditions, and what order extrapolation you want, and so forth? And if
> not, does it then ONLY make a difference if I’m working with more than on
> processor, ie. If everything is sequential, is DMDA_BOUNDARY_GHOSTED and
> DMDA_BOUNDARY_NONE equivalent?****
> GHOSTED adds extra space at the boundary so you can always use the same
> stencil, but you decide what goes in there. ****
> Does this apply to both matrices and vectors, ie. Will the ghost points be
> considered part of my computational domain or not?
The ghost nodes only exist in local vectors, not the global vectors for the
solver.
  Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111202/2fa9fd1a/attachment.htm>
