[petsc-users] many valgrind error of petsc string functions
Fri Dec 2 06:28:02 CST 2011
2011/12/2 Gong Ding <gdiso at ustc.edu>
> Valgrind reported many errors about string processing functionss of petsc.
> These error seems harmless, but really ugly.
Agreed, I think you have a really long path (but still much shorter than
the system path length). If this is the problem, then the fix I just pushed
to petsc-3.2 will fix it.
http://petsc.cs.iit.edu/petsc/releases/petsc-3.2/rev/36bd87d582e9
You can pull this with mercurial or apply manually. Let me know if this
works.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111202/02424133/attachment.htm>
