[petsc-users] local row calculation in 3D
ilyas ilyas ilyascfd at gmail.com
Tue Apr 19 02:00:14 CDT 2011
Hi Randy,
Thank you for your answer.
I have already done it. You can see it in my first e-mail.
It does not work properly for all number of processors.
For certain number of processors, it works correctly,
not for all number of processors.
For example, for 1,2,or 3 processors, it's ok.
For 4 processors, it gives wrong location, so on.
"Problem" occurs in 3rd dimension ( (kk-gzs)*gxm*gym )
Here is another suggestion (I have not tried yet) ;
       do kk=zs,zs+zm-1
        do jj=ys,ys+ym-1
          do ii=xs,xs+xm-1
            row=ii-gxs + (jj-gys)*MX + (kk-gzs)*MX*MY
MX,MY,MZ are global dimensions.This is also what I do serially
Do you think that it is correct or any other suggestions?
Ilyas.
2011/4/18 Randall Mackie <rlmackie862 at gmail.com>
> Here's how I do it:
>        do kk=zs,zs+zm-1
>         do jj=ys,ys+ym-1
>           do ii=xs,xs+xm-1
>              row=ii-gxs + (jj-gys)*gxm + (kk-gzs)*gxm*gym
> Good luck,
> Randy M.
> On Mon, Apr 18, 2011 at 6:54 AM, ilyas ilyas <ilyascfd at gmail.com> wrote:
>> Hi,
>> Thank you for your suggestion. I will take it into account.
>> Since changing this structure in my "massive" code may take  too much
>> time,
>> I would like to know that how "row" is calculated in 3D, independently
>> from processor numbers.
>> Regards,
>> Ilyas
>> 2011/4/18 Matthew Knepley <knepley at gmail.com>
>>> On Mon, Apr 18, 2011 at 8:34 AM, ilyas ilyas <ilyascfd at gmail.com> wrote:
>>>> Hi,
>>>> In ex14f.F in KSP, "row" variable is calculated either
>>> These are very old. I suggest you use the FormFunctionLocal() approach in
>>> ex5f.F which
>>> does not calculate global row numbers when using a DA.
>>>    Matt
>>>> 349: do 30 j=ys,ys+ym-1
>>>> 350: ...
>>>> 351: do 40 i=xs,xs+xm-1
>>>> 352:          row = i - gxs + (j - gys)*gxm + 1
>>>> or
>>>> 442: do 50 j=ys,ys+ym-1
>>>> 443: ...
>>>> 444: row = (j - gys)*gxm + xs - gxs
>>>> 445: do 60 i=xs,xs+xm-1
>>>> 446:          row = row + 1
>>>> How can I calculate "row" in 3D ?
>>>> I tried this;
>>>> do k=zs,zs+zm-1
>>>>    do j=ys,ys+ym-1
>>>>       do i=xs,xs+xm-1
>>>>            row = i - gxs + (j - gys)*gxm + (k - gzs)*gxm*gym + 1
>>>> It does not work for certain number of processors.
>>>> Thanks,
>>>> Ilyas
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110419/0d6868e6/attachment-0001.htm>
