[petsc-users] Pre-conditioner for parallel CFD simulation
Fri Apr 15 06:34:18 CDT 2011
On Fri, Apr 15, 2011 at 5:51 AM, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
> Jed Brown wrote:
>  On Fri, Apr 15, 2011 at 12:06, Thomas Witkowski <
>> thomas.witkowski at tu-dresden.de <mailto:thomas.witkowski at tu-dresden.de>>
>> wrote:
>>    Which package must be installed to make use of "ml" (algebraic
>>    multigrid?) as a preconditioner?
>> ML, --download-ml
>> also -pc_type hypre (BoomerAMG is default) from, you guessed it, Hypre,
>> --download-hypre
> But it works with MatAIJ with MatSetBlockSize(x). What is the difference
> between using MatBAIJ and MatAIJ with setting the block size directly?
BAIJ changes the internal storage format to make things run faster. ML does
not handle this.
   Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110415/7d036e81/attachment.htm>
