[petsc-users] Pre-conditioner for parallel CFD simulation
Thomas Witkowski thomas.witkowski at tu-dresden.de
Fri Apr 15 05:38:56 CDT 2011
Jed Brown wrote:
> On Fri, Apr 15, 2011 at 12:06, Thomas Witkowski
> <thomas.witkowski at tu-dresden.de
> <mailto:thomas.witkowski at tu-dresden.de>> wrote:
>     Which package must be installed to make use of "ml" (algebraic
>     multigrid?) as a preconditioner?
> ML, --download-ml
> also -pc_type hypre (BoomerAMG is default) from, you guessed it,
> Hypre, --download-hypre
I tried it, but when I make use of BAIJ matrix format, as you have
proposed, I get the following error:
Invalid matrix type for ML. ML can only handle AIJ matrices.!
So can I make use of algebraic multigrid on block size matrices with
this or one of the other packages?
Thomas
