[petsc-users] Is there efficeint method for matrix with one extremely small eigen value?
Umut Tabak u.tabak at tudelft.nl
Wed Apr 6 10:24:23 CDT 2011
On 04/06/2011 04:50 PM, Jed Brown wrote:
> On Wed, 06 Apr 2011 16:37:26 +0200, Umut Tabak <u.tabak at tudelft.nl>
> wrote:
>> Just curious, are not the other negative eigenvalues problematic as
>> well?
> Negative eigenvalues do not pose any particular problem to Krylov
> methods like GMRES. Conjugate gradients does require that the matrix
> be SPD, but petsc-dev detects when a matrix is negative definite and
> still does the right thing.
Also with cg type methods? if yes, how?
Because I am dealing with a similar problem in a projection sense which
makes some factors that are already available very good preconditioners,
completely problem specific, then cg converges incredibly fast, sth like
4 to 8 iterations. However, projection is the key and at every step, in
cg, I should make sure that the search directions in cg are orthogonal
to the previous ones by cgs/mgs, otherwise I bump into the well know
orthogonality issues of Lanczos type methods...
why I am digging is to see some better options if there are any.
Greetz,
Umut
