[petsc-users] compile errors with petsc-dev
Mon Apr 4 13:46:08 CDT 2011
On Mon, Apr 4, 2011 at 1:41 PM, Gaurish Telang <gaurish108 at gmail.com> wrote:
> Hi,
> I have installed two versions of PETSc on my computer,  the debug version
> petsc-3.1.p7 and petsc-dev.
> However, when I try to compile my codes  with petsc-dev(which were
> successfully compiled and executed under the first version)
> I get lots of compile errors.
> Why could this be happening? I have pasted the error message below.
http://www.mcs.anl.gov/petsc/petsc-as/documentation/changes/dev.html
The first item.
   Matt
> gaurish108 at telang:~/Desktop/LSQR_progress$ $PETSC_DIR
> bash: /home/gaurish108/software/petsc-dev: is a directory
> gaurish108 at telang:~/Desktop/LSQR_progress$ make main
> /home/gaurish108/software/petsc-dev/linux-gnu-c/bin/mpicc -o main.o -c
> -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3
> -I/home/gaurish108/software/petsc-dev/include
> -I/home/gaurish108/software/petsc-dev/linux-gnu-c/include -D__INSDIR__=
> main.c
> main.c: In function ‘main’:
> main.c:17: error: ‘PetscTruth’ undeclared (first use in this function)
> main.c:17: error: (Each undeclared identifier is reported only once
> main.c:17: error: for each function it appears in.)
> main.c:17: error: expected ‘;’ before ‘flg_b’
> main.c:26: error: ‘flg_b’ undeclared (first use in this function)
> main.c:27: error: macro "SETERRQ" requires 3 arguments, but only 2 given
> main.c:27: error: ‘SETERRQ’ undeclared (first use in this function)
> main.c:30: warning: passing argument 1 of ‘VecLoad’ from incompatible
> pointer type
> /home/gaurish108/software/petsc-dev/include/petscvec.h:419: note: expected
> ‘Vec’ but argument is of type ‘PetscViewer’
> main.c:30: warning: passing argument 2 of ‘VecLoad’ from incompatible
> pointer type
> ‘PetscViewer’ but argument is of type ‘const char *’
> main.c:30: error: too many arguments to function ‘VecLoad’
> main.c:37: error: ‘flg_A’ undeclared (first use in this function)
> main.c:38: error: macro "SETERRQ" requires 3 arguments, but only 2 given
> main.c:41: warning: passing argument 1 of ‘MatLoad’ from incompatible
> pointer type
> /home/gaurish108/software/petsc-dev/include/petscmat.h:493: note: expected
> ‘Mat’ but argument is of type ‘PetscViewer’
> main.c:41: warning: passing argument 2 of ‘MatLoad’ from incompatible
> pointer type
> main.c:41: error: too many arguments to function ‘MatLoad’
> make: [main.o] Error 1 (ignored)
> /home/gaurish108/software/petsc-dev/linux-gnu-c/bin/mpicc -Wall
> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3  -o main
> main.o -L/home/gaurish108/software/petsc-dev/linux-gnu-c/lib  -lpetsc -lX11
> -Wl,-rpath,/home/gaurish108/software/petsc-dev/linux-gnu-c/lib -lflapack
> -lfblas -lm -L/usr/lib/gcc/i686-linux-gnu/4.4.5 -L/usr/lib/i686-linux-gnu
> -ldl -lmpich -lopa -lmpl -lrt -lpthread -lgcc_s -lmpichf90 -lgfortran -lm
> -lm -ldl -lmpich -lopa -lmpl -lrt -lpthread -lgcc_s -ldl
> gcc: main.o: No such file or directory
> make: [main] Error 1 (ignored)
> /bin/rm -f main.o
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110404/dc6dcd24/attachment.htm>
