[petsc-users] Performance of superlu_dist
Ormiston, Scott J. SJ_Ormiston at UManitoba.ca
Fri Apr 1 10:40:16 CDT 2011
Desire NUENTSA WAKAM wrote:
> On a multicore node, you may not get a very good speedup if the
> bandwidth is heavily shared between all the cores. I guess this is what
> Petsc people have explained here
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#computers
> If you have a multi-socket multicore node, my guess would be to keep one
> MPI  process on each socket and then to use a multithreaded BLAS (like
> Goto) inside each socket to keep the cores busy during BLAS operations.
> Hope this helps
It was very helpful.
Merci infiniment.
Scott Ormiston
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110401/6eba68bd/attachment.vcf>
