[petsc-users] Performance of superlu_dist
Ormiston, Scott J. SJ_Ormiston at UManitoba.ca
Fri Apr 1 08:43:12 CDT 2011
I am just starting to try superlu_dist to get a direct solver that runs
in parallel with PETSc.
My first tests (with ex15f) show that it takes longer and longer as the
number of cores increases. For example 4 cores takes 8 times longer than
2 cores and 8 cores takes 25 times longer than 4 cores.  Obviously I
expected a speed-up; has anyone else seen this behaviour with
superlu_dist? If not, what could be going wrong here?
Scott Ormiston
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110401/8e226406/attachment.vcf>
