[petsc-users] Read in sequential, solve in parallel
Moinier, Pierre (UK) Pierre.Moinier at baesystems.com
Wed Sep 29 10:05:07 CDT 2010
Thanks for your help!
Dr Pierre Moinier
Principal Research Scientist
Office ': +44 (0)117 302 8223  >  pierre.moinier at baesystems.com | ü www.baesystems.com <http://www.baesystems.com/>
BAE Systems ¦ Advanced Technology Centre ¦ Sowerby Building (20R) ¦ FPC 267 ¦ PO Box 5 ¦ Filton ¦ Bristol ¦ BS34 7QW
BAE Systems (Operations) Limited
Registered Office: Warwick House, PO Box 87, Farnborough Aerospace Centre, Farnborough, Hants, GU14 6YU, UK
Registered in England & Wales No: 1996687
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Jed Brown
Sent: 29 September 2010 16:04
To: PETSc users list
Subject: Re: [petsc-users] Read in sequential, solve in parallel
                    *** WARNING ***
  This message has originated outside your organisation,
  either from an external partner or the Global Internet.
      Keep this in mind if you answer this message.
The stage totals are aggregate. More info in the users manual. You can add stages to distinguish between different phases of your program.
Your results look good except for the dot/norm timing but that won't make s big difference.
Jed
	On Sep 29, 2010 4:34 PM, "Moinier, Pierre (UK)" <Pierre.Moinier at baesystems.com> wrote:
	Jed,
	You are right I built the matrix from a Poisson problem using a 5pts
	discretization.
	I have now found out why I wasn't getting the correct scaling. That was
	due to a silly mistake in submitting my executable.
	With 4 cores, I get:
	--- Event Stage 0: Main Stage
	MatMult             1633 1.0 6.9578e+00 1.2 3.67e+09 1.0 9.8e+03 8.0e+03
	0.0e+00 41 43100 59  0  41 43100 59  0  2110
	MatAssemblyBegin       1 1.0 1.8351e-01182.2 0.00e+00 0.0 0.0e+00
	0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
	MatAssemblyEnd         1 1.0 1.6289e-02 1.0 0.00e+00 0.0 1.2e+01 2.0e+03
	7.0e+00 0 0 0 0 0 0 0 0 0 0 0
	MatLoad                1 1.0 6.6239e-01 1.0 0.00e+00 0.0 2.1e+01 2.3e+06
	9.0e+00  4  0  0 36  0   4  0  0 36  0     0
	VecDot              3266 1.0 2.3861e+00 1.6 1.63e+09 1.0 0.0e+00 0.0e+00
	3.3e+03 11 19  0  0 66  11 19  0  0 66  2737
	VecNorm             1634 1.0 3.8494e+00 1.2 8.17e+08 1.0 0.0e+00 0.0e+00
	1.6e+03 23 10  0  0 33  23 10  0  0 33   849
	VecCopy             1636 1.0 1.0704e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
	0.0e+00 5 0 0 0 0 5 0 0 0 0 0
	VecSet                 1 1.0 6.0201e-04 2.3 0.00e+00 0.0 0.0e+00 0.0e+00
	0.0e+00 0 0 0 0 0 0 0 0 0 0 0
	VecAXPY             3266 1.0 2.0010e+00 1.2 1.63e+09 1.0 0.0e+00 0.0e+00
	0.0e+00 11 19  0  0  0  11 19  0  0  0  3264
	VecAYPX             1632 1.0 8.4769e-01 1.4 8.16e+08 1.0 0.0e+00 0.0e+00
	0.0e+00  4 10  0  0  0   4 10  0  0  0  3850
	VecAssemblyBegin       1 1.0 3.3454e-02477.3 0.00e+00 0.0 0.0e+00
	0.0e+00 3.0e+00  0  0  0  0  0   0  0  0  0  0     0
	VecAssemblyEnd         1 1.0 3.0994e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
	VecLoad                1 1.0 7.2319e-02 1.0 0.00e+00 0.0 3.0e+00 2.0e+06
	4.0e+00  0  0  0  5  0   0  0  0  5  0     0
	VecScatterBegin     1633 1.0 2.4417e-02 2.3 0.00e+00 0.0 9.8e+03 8.0e+03
	0.0e+00  0  0100 59  0   0  0100 59  0     0
	VecScatterEnd       1633 1.0 1.0537e+0024.4 0.00e+00 0.0 0.0e+00 0.0e+00
	0.0e+00 3 0 0 0 0 3 0 0 0 0 0
	KSPSetup               1 1.0 2.6400e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
	KSPSolve               1 1.0 1.5425e+01 1.0 8.57e+09 1.0 9.8e+03 8.0e+03
	4.9e+03 95100100 59 99  95100100 59100  2222
	PCSetUp 1 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
	0.0e+00 0 0 0 0 0 0 ...
	PCApply             1634 1.0 1.0700e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
	For a single core, I was getting 4.4828e+01 for KSPSolve.
	I am correct to assume that what is listed as "Event Stage 0: Main
	Stage" is common to each core?
	Finally, what is the meaning of "Event Stage 0: Main Stage"
	Cheers,
	       -Pierre.
	This email and any attachmen...
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender.
You should not copy it or use it for any purpose nor disclose or
distribute its contents to any other person.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100929/67e285fc/attachment.htm>
