[petsc-users] Problem with mpi
TAY Wee Beng zonexo at gmail.com
Fri Oct 29 10:16:25 CDT 2010
I have a mpi code which works fine in my previous clusters.
However, there's mpi problem when I use it in the new clusters, which
use openmpi. I wonder if there's a relation.
The error is:
[n12-70:14429] *** An error occurred in MPI_comm_size
[n12-70:14429] *** on communicator MPI_COMM_WORLD
[n12-70:14429] *** MPI_ERR_COMM: invalid communicator
[n12-70:14429] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
2.48user 0.45system 0:03.99elapsed 73%CPU (0avgtext+0avgdata
2871936maxresident)k
0inputs+0outputs (0major+185587minor)pagefaults 0swaps
mpiexec has exited due to process rank 3 with PID 14425 on
node n12-70 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpiexec (as reported here).
[n12-70:14421] 3 more processes have sent help message
help-mpi-errors.txt / mpi_errors_are_fatal
[n12-70:14421] Set MCA parameter "orte_base_help_aggregate" to 0 to see
all help / error messages
I am not sure what other information you will need. I will provide more
information if required. I tried running on 1, 4 and 8 processors but
all can't work.
Yours sincerely,
TAY Wee Beng
