[petsc-users] Bug when multipling a SBAIJ matrix with a vector
Andreas Hauffe andreas.hauffe at tu-dresden.de
Thu Oct 21 08:23:32 CDT 2010
Am Donnerstag 21 Oktober 2010, 15:08:39 schrieb Jed Brown:
> On Thu, Oct 21, 2010 at 14:41, Andreas Hauffe
> <andreas.hauffe at tu-dresden.de> wrote:
> > I get no error and this example delivers the right result for PETSC 3.0.
> > What did change from 3.0 to 3.1?
> Many of the matrix kernels were optimized, this one was changed in
> relatively simple ways, but the data structures for factorization were
> changed completely.  In this case, Barry's name is on the commit
> message
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/0308bd570415#l2.33
> He should have put that behavioral change in the 3.1 changelog.  Or
> maybe the cost of handling empty rows is actually not significant so
> it should still be supported.  I can't tell from the commit message,
> but empty rows are still supported by the code in MatMult_SeqSBAIJ_2,
> so it probably should work for block size 1 as well.
> Do you really not get an error message when you run your example code
> with 3.1 built with debug support?  I just ran your code with 3.1 and
> I get a (bad) error message.
> Jed
Thanks for the answer.
I forgott to use a debug version of PETSC. Sorry! Now I get the error.
Best regards,
Andreas Hauffe
Technische Universität Dresden
Institut für Luft- und Raumfahrttechnik / Institute of Aerospace Engineering
Lehrstuhl für Luftfahrzeugtechnik / Chair of Aircraft Engineering
D-01062 Dresden
Germany
phone   : (++49)351 463 38496
fax     : (++49)351 463 37263
mail    : andreas.hauffe at tu-dresden.de
Website : http://tu-dresden.de/mw/ilr/lft
