[petsc-users] Bug when multipling a SBAIJ matrix with a vector
Andreas Hauffe andreas.hauffe at tu-dresden.de
Thu Oct 21 07:41:48 CDT 2010
Am Donnerstag 21 Oktober 2010, 14:24:59 schrieb Jed Brown:
> The SBAIJ implementation requires that the diagonal entry exists.  If you
> only have a few rows of all zeros, then just place explicit zeros there,
> otherwise use AIJ or BAIJ both of which work fine with completely empty
> rows (if your system is so sparse that you don't want to store one
> explicit zero per row, then the non-symmetric storage will probably also
> be faster.
> Aren't you getting an error in MatMult_SeqSBAIJ_1?  This is a horrible
> error message, but it comes from trying to log a negative number of flops.
>  I'll put a check into petsc-dev so it gives a better error message.
> Jed
I get no error and this example delivers the right result for PETSC 3.0. What
did change from 3.0 to 3.1?
So I will but 0 to the diagonal.
best regards,
Andreas Hauffe
Technische Universität Dresden
Institut für Luft- und Raumfahrttechnik / Institute of Aerospace Engineering
Lehrstuhl für Luftfahrzeugtechnik / Chair of Aircraft Engineering
D-01062 Dresden
Germany
phone   : (++49)351 463 38496
fax     : (++49)351 463 37263
mail    : andreas.hauffe at tu-dresden.de
Website : http://tu-dresden.de/mw/ilr/lft
