[petsc-users] DASetCoordinates
Randall Mackie rlmackie862 at gmail.com
Wed Oct 6 16:19:50 CDT 2010
> > Maybe I'm just being dense, but I don't see how or where I set these at
> each level within
> > the DMMG framework.  Isn't all that buried within the DMMG routines, or
> is there some
> > way for me to specify this?
> It's kinda raw:
>    for (i=0; i<DMMGGetLevels(dmmg); i++) {
>      DA da = (DA)dmmg[i]->dm;
>      /* Set coordinates */
I'm trying to write a wrapper in c to do this, but as a first step I'm just
trying to set
uniform coordinates at each level. However, I am simultaneously trying to
learn c, learn about pointers,
and figure out how this all works with PETSc, and I am having a problem
which is probably
very obvious to you expert c programmers, but not obvious to me (a long-time
fortran programmer).
Here is what I have so far, which is based largely on what Jed wrote above
and zdmmg.c which
is one of the Fortran wrappers you guys have written:
#include "private/fortranimpl.h"
#include "petscda.h"
#include "petscdmmg.h"
#if defined(PETSC_HAVE_FORTRAN_CAPS)
#define dasetcoords_          DASETCOORDS
#elif !defined(PETSC_HAVE_FORTRAN_UNDERSCORE)
#define dasetcoords_          dasetcoords
#endif
EXTERN_C_BEGIN
void PETSC_STDCALL dasetcoords_(DMMG **dmmg, PetscErrorCode *ierr)
 PetscInt i, nlev;
 nlev = DMMGGetLevels(*dmmg);
 printf("The number of levels is %d \n",nlev);
 for (i=0; i < nlev; i++){
  *ierr = DASetUniformCoordinates(da,0.0,1.0,0.0,1.0,0.0,1.0);
EXTERN_C_END
But when I compile it I get:
dasetcoords.c(22): error: expression must have pointer-to-struct-or-union
type
So, I've tried various things, but can't figure out how to do this
correctly. Can someone who
is a c expert help me here on how to get the DA set for each level?
Thanks, Randy M.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101006/e4453cdd/attachment.htm>
