[petsc-users] preallocation for FE matrix
    Tabrez Ali
    stali at geology.wisc.edu
    Mon Oct  4 16:21:47 CDT 2010
I am trying to assemble a FE matrix (adding one element at a time from
the local stiffness matrix) and cant seem to get the preallocation
right. I am correctly calculating the number of non zeros per row and
storing the value in the array [nnzpr].
Here is part of the relevant code
call MatCreateSeqBAIJ(Petsc_Comm_Self, 1, m, n, petsc_null_integer,
nnzpr, Mat_A, ierr)
! Assume a bilinear quad (2 dof per node)
do j1=1,8
  do j2=1,8
    call MatSetValues(Mat_A, 1, indx(j1)-1, 1, indx(j2)-1, k(j1,j2),
Add_Values, ierr)
  end do
end do
call MatAssemblyBegin(Mat_A,Mat_Final_Assembly,ierr)
call MatAssemblyEnd(Mat_A,Mat_Final_Assembly,ierr)
On running it I get
-bash-3.00$ ./a.out <inp -info -mat_view_info
 Total non-zero elements estimated i.e., sum(nnzpr) =                  112
[0] PetscCommDuplicate(): Duplicating a communicator 1140850689
-2080374784 max tags = 2147483647
[0] PetscCommDuplicate():   returning tag 2147483647
[0] MatAssemblyEnd_SeqBAIJ(): Matrix size: 12 X 12, block size 1;
storage space: 42 unneeded, 112 used
[0] MatAssemblyEnd_SeqBAIJ(): Number of mallocs during MatSetValues is 9
[0] MatAssemblyEnd_SeqBAIJ(): Most nonzeros blocks in any row is 12
Matrix Object:
  type=seqbaij, rows=12, cols=12
  total: nonzeros=112, allocated nonzeros=154
      block size is 1
I dont understand why -mat_view_info shows allocated nonzeros to be 154
when sum(nnzpr) is 112.
Thanks in advance.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101004/135478d7/attachment.htm>
