[petsc-users] MatPermuteSparsify hanging
Kelly Fermoyle kjf198 at cse.psu.edu
Mon Nov 29 16:23:01 CST 2010
This is what I got on a desktop. It looks a lot more reasonable. I stopped
it after a while and it appears to be in MatSetValues.
[Thread 0x40200940 (LWP 26776) exited]
Program received signal SIGINT, Interrupt.
0x0000000000accb16 in PetscMemcpy (a=0x2aaab7b499b0, b=0x2aaab6de4938,
n=1796808) at memc.c:104
104	    memcpy((char*)(a),(char*)(b),n);
(gdb) backtrace full
#0  0x0000000000accb16 in PetscMemcpy (a=0x2aaab7b499b0, b=0x2aaab6de4938,
        al = 46912714873264
        bl = 46912700827960
        nl = 1796808
#1  0x000000000069b8f9 in MatSetValues_SeqAIJ (A=0x1430490, m=1,
im=0x7fffffffd270, n=21, in=0x2aaab2c76200, v=0x2aaab2d9a200,
    is=INSERT_VALUES) at aij.c:225
        len = 224601
        new_j = 0x2aaab7d01200
        Ain = 0x1431620
        new_nz = 1755215
        new_i = 0x2aaab83b4200
        new_a = 0x2aaab6f9c200
        a = 0x1431620
        rp = 0x2aaab89c5d48
        k = 0
        low = 18
        high = 21
        t = 18
        ii = 59410
        row = 52376
        nrow = 21
        i = 21
        col = 52922
        l = 0
        rmax = 21
        N = 37
        imax = 0x2aaab2e0f200
        ai = 0x2aaab8aa2200
        ailen = 0x2aaab2e4a200
        ierr = 0
        aj = 0x2aaab83ef200
        nonew = 0
        lastcol = 52922
        ap = 0x2aaab6de4890
        value = 25472.555765646161
        aa = 0x2aaab6237200
        ignorezeroentries = PETSC_FALSE
        roworiented = PETSC_TRUE
#2  0x000000000061c324 in MatSetValues (mat=0x1430490, m=1,
idxm=0x7fffffffd270, n=21, idxn=0x2aaab2c76200, v=0x2aaab2d9a200,
    addv=INSERT_VALUES) at matrix.c:921
        ierr = 0
#3  0x00000000006426d7 in MatPermuteSparsify (A=0x141a1a0, band=-1,
frac=0, tol=0.001, rowp=0x13fde70, colp=0x142e630,
    B=0x7fffffffd678) at matrix.c:4157
        irowp = 0x142f050
        icolp = 0x142fa70
        rows = 0x2aaab2cb1200
        cols = 0x2aaab2cec200
        M = 59409
        N = 59409
        locRowStart = 0
        locRowEnd = 59409
        nz = 21
        newNz = 21
        cwork = 0x2aaab5271a24
        cnew = 0x2aaab2c76200
        vwork = 0x2aaab4bdd248
        vnew = 0x2aaab2d9a200
        bw = 2970
        issize = 59409
        row = 27126
        locRow = 27126
        newRow = 52376
        col = 21
        newCol = 52382
        ierr = 0
#4  0x000000000043822f in main (argc=17, argv=0x7fffffffd7a8) at
SolveTest.cpp:54
        ksp = 0x7fff00000001
        colp = 0x142e630
---Type <return> to continue, or q <return> to quit---
        vec_file =
"/gpfs/home/kjf198/group/kjf198/SYMMETRIC_MATRICES/20-0.vec\000\000\000\000\000\000\200\325\377\377\377\177\000\000i4\271\255\252*\000\000\250\065\062\001\000\000\000\000\023\000\000\000\252*\000\000\300\065\062\001\000\000\000\000\001\000\000\000\000\000\000\000\250\065\062\001\000\000\000\000\221
\226\256\252*\000\000\303\312\363\000\000\000\000\000\340,\226\256\252*\000\000\250\335\037\001\000\000\000\000\303\312\363\000\000\000\000\000\060\326\377\377\377\177\000\000\000\260\036\001\000\000\000\000\070\330\377\377\377\177\000\000b.\226\256\252*\000\000\000\330\377\377\377\177\000\000\000\260\036\001\000\000\000\000@\326\377\377\377\177\000\000\201\065\343M4\000\000\000\000\260\036\001\000\000\000\000@\326\377\377\377\177\000\000\000\260\036\001\000\000\000\000\t\204C\000\000\000\000"
        mat_file =
"/gpfs/home/kjf198/group/kjf198/SYMMETRIC_MATRICES/20-0.mat\000\377\377\177\000\000\000\020\214\256\252*\000\000>\340\215\256\252*\000\000`\023\214\256\252*\000\000\260\325\377\377\377\177\000\000\000\020\214\256\000\000\000\000\300®\257\252*\000\000`\263\252\252\252*\000\000\320\325\377\377\377\177\000\000\000\260\252\252\252*\000\000\023\246A\000\000\000\000\000`\263\252\252\252*\000\000\360\325\377\377\377\177\000\000\020\224\214\256\252*\000\000\000\020\214\256\252*\000\000\360\233\340M4\000\000\000\340\024\214\256\252*\000\000`\020\273\256\000\000\000\000y:<\a\000\000\000\000\000\260\036\001\000\000\000\000H[/\000\000\000\000\000\b(2\001\000\000\000\000\021\000\000\000\000\000\000\000\250\327\377\377\377\177\000\000\070\330\377\377\377\177\000"
        reordering = "rcm", '\000' <repeats 252 times>
        b = 0x13f6e30
        rowp = 0x13fde70
        ierr = 0
        timestep = 20
        x = 0x13fb6c0
        start = 1.1098831058709664e-312
        type = 0xecbb5a "rcm"
        iters = 15513927
        A = 0x141a1a0
        P = 0x1430490
        residual = 2.1861090613857222e-317
        threshold = 0.001
        mat_view = 0x13fb6c0
        vec_view = 0x13fb6c0
        iteration = 0
        end = 7.6648711891784312e-317
> On Mon, Nov 29, 2010 at 20:28, Kelly Fermoyle <kjf198 at cse.psu.edu> wrote:
>> I am using a Cray machine and it requires that I call as aprun -n 1
>> ./prog_name, which does not seem to work with -start_in_debugger.
> Can you reproduce with the same code on a local machine (e.g.
> desktop/laptop) where you can get a proper debugging session?
>> Below is the output of the full backtrace:
> This trace is not even in your code
>> #2  0x0000000000403be7 in main (argc=20, argv=0x7fffe2814538) at
> aprun.c:225
> Jed
