[petsc-users] Printing parallel Vector in VTK format
khalid ashraf khalid_eee at yahoo.com
Fri Nov 26 17:02:14 CST 2010
Thanks Jed and Barry. It works fine now.
Khalid
From: "petsc-users-request at mcs.anl.gov" <petsc-users-request at mcs.anl.gov>
To: petsc-users at mcs.anl.gov
Sent: Fri, November 26, 2010 10:00:19 AM
Subject: petsc-users Digest, Vol 23, Issue 29
Send petsc-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
    https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    petsc-users-owner at mcs.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of petsc-users digest..."
Today's Topics:
   1.  Global DA index using DAGetCorners (khalid ashraf)
   2. Re:  Global DA index using DAGetCorners (Barry Smith)
   3. Re:  Printing parallel Vector in VTK format (khalid ashraf)
   4. Re:  Printing parallel Vector in VTK format (Jed Brown)
   5. Re:  Printing parallel Vector in VTK format (Barry Smith)
Message: 1
Date: Thu, 25 Nov 2010 17:50:21 -0800 (PST)
Subject: [petsc-users] Global DA index using DAGetCorners
Message-ID: <113982.45603.qm at web112617.mail.gq1.yahoo.com>
Content-Type: text/plain; charset="us-ascii"
It doesn't seem like the problem is with the natural ordering. Since in Fig.9 of
the manual,
the highest number of the grid should be the same(30 in fig. 9) for natural and
petsc ordering.
But I get a lower number when I print it.
I also tried the petsc to natural conversion using the following code,
    ia[0]=(PetscInt)((k)*(my)*(mx)+(j)*(mx)+(i));
    AOPetscToApplication(ao,1,ia);
     w_localptr[k][j][i] = ia[0];
PetscPrintf(PETSC_COMM_WORLD,"%d\n",ia[0]);
But this gives even lower number for the highest index.
Anyway my goal is to be able to determine the global natural index of the
grid within the for loops in the following way:
for (k=zs; k<zs+zm; k++) {
  for (j=ys; j<ys+ym; j++) {
  for (i=xs; i<xs+xm; i++) {
natural_global_coordinate(k',j',i')=f(k,j,i);
if natural_global_coord[k'][j'][i'] > half of the grid along x {Do something}
if natural_global_coord[k'][j'][i'] > half of the grid along y {Do something}
etc..
Could you please suggest what would be the simplest way to achieve this.
Thanks in advance.
URL:
<http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101125/ff463aaa/attachment-0001.htm>
Message: 2
Date: Thu, 25 Nov 2010 20:31:17 -0600
Subject: Re: [petsc-users] Global DA index using DAGetCorners
To: PETSc users list <petsc-users at mcs.anl.gov>
Message-ID: <B39F8696-63EC-4C5B-83D2-AA0ECAA6A073 at mcs.anl.gov>
Content-Type: text/plain; charset=us-ascii
>of the manual,
>petsc ordering.
     This give the natural number of the location in ia[0]
    So it makes no sense to call AOPetscToApplication() to map it to something
else. It is already in the natural (i.e. application ordering)
      i  > m/2  means means it is in the right half of the grid along x (where m
is the number of grid points in the x direction).
      To determine these things you don't need to do anything about mapping
between orderings.
      You are chasing yourself in circles to do something that is essentially
trivial. With the loop structure you have above, the i,j,k ARE exactly the
logical locations in the global X, Y, Z grid. It couldn't be simplier.
   Barry
> etc..
> Thanks in advance.
Message: 3
Date: Thu, 25 Nov 2010 21:36:08 -0800 (PST)
Subject: Re: [petsc-users] Printing parallel Vector in VTK format
Message-ID: <804366.55079.qm at web112616.mail.gq1.yahoo.com>
Thanks Barry. I get the correct output when I use
VecView(w,PETSC_VIEWER_STDOUT_WORLD)
But if I use the VecView_VTK function from the file
ksp/ksp/examples/tutorials/ex29.c
then I get different results.
For the code:
if (i<m/2) vec=0.001 else vec=-0.001;
Output with VecView:     0.001 for half of the grid
                                    -0.001 for rest half of the grid
Output with VecView_VTK:
                                 0.001 for the full grid.
Date: Thu, 25 Nov 2010 02:24:52 -0800 (PST)
Subject: [petsc-users] DAGetCorners; xs,ys,zs return 0 for all the
    processors
Message-ID: <588844.78157.qm at web112619.mail.gq1.yahoo.com>
Here is the call to DA creation:
ierr =
DACreate3d(PETSC_COMM_WORLD,DA_NONPERIODIC,DA_STENCIL_BOX,appctx.l,appctx.m,appctx.n,
PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,1,1,PETSC_NULL,PETSC_NULL,PETSC_NULL,
                    &appctx.da);CHKERRQ(ierr);
Khalid
URL:
<http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101125/d0590ec8/attachment-0001.htm>
Message: 2
Date: Thu, 25 Nov 2010 11:35:43 +0100
Subject: Re: [petsc-users] DAGetCorners;    xs,ys,zs return 0 for all the
    processors
Message-ID:
    <AANLkTineq3bTG=iRsjkdoY2ZhZ9ac7r8vBmSUqEpOvu5 at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
On Thu, Nov 25, 2010 at 11:24, khalid ashraf <khalid_eee at yahoo.com> wrote:
> ierr =
If you created the DA as above and then call
  DAGetCorners(appctx.da,&xs,&ys,&zs,&xm,&ym,&zm);
then only on rank=0 will xs,ys,zs all be equal to zero.  Your other message
about PETSc versus natural ordering indicates that this is working
correctly.  Is it working now?  If not, please send more context, including
whatever code you are using to print output.
Jed
URL:
<http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101125/6da538a3/attachment-0001.htm>
End of petsc-users Digest, Vol 23, Issue 28
URL:
<http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101125/d2817c38/attachment-0001.htm>
Message: 4
Date: Fri, 26 Nov 2010 10:13:31 +0100
Message-ID:
    <AANLkTikLk3g3xgGnVbDTtB4Wcr7HcuJeLyn9ejWuMBEg at mail.gmail.com>
On Fri, Nov 26, 2010 at 06:36, khalid ashraf <khalid_eee at yahoo.com> wrote:
This is a crucial piece of information, if you stated this in the first
email, you would have gotten a good answer to your first email.
The problem is that this function and the copy in ex50.c, never worked in
parallel.  Clearly the person who wrote it misunderstood the VTK legacy
format because nothing similar can work in parallel.  See
src/snes/examples/tutorials/ex5.c for the correct way to do it:
    PetscViewer viewer;
    ierr = PetscViewerCreate(PETSC_COMM_WORLD, &viewer);CHKERRQ(ierr);
    ierr = PetscViewerSetType(viewer, PETSCVIEWERASCII);CHKERRQ(ierr);
    ierr = PetscViewerFileSetName(viewer, "ex5_sol.vtk");CHKERRQ(ierr);
    ierr = PetscViewerSetFormat(viewer,
PETSC_VIEWER_ASCII_VTK);CHKERRQ(ierr);
    ierr = DAView(user.da, viewer);CHKERRQ(ierr);
    ierr = VecView(x, viewer);CHKERRQ(ierr);
    ierr = PetscViewerDestroy(viewer);CHKERRQ(ierr);
Jed
URL:
<http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101126/31c1b6cf/attachment-0001.htm>
Message: 5
Date: Fri, 26 Nov 2010 10:42:04 -0600
Message-ID: <8A1D2053-2CC5-44E6-AC92-AAE60D7CF966 at mcs.anl.gov>
  Jed,
    Can you please remove that bad code from those two examples if you haven't
yet.
    Thanks
   Barry
> This is a crucial piece of information, if you stated this in the first email,
>parallel.  Clearly the person who wrote it misunderstood the VTK legacy format
>     PetscViewer viewer;
>     ierr = PetscViewerSetFormat(viewer, PETSC_VIEWER_ASCII_VTK);CHKERRQ(ierr);
> Jed
End of petsc-users Digest, Vol 23, Issue 29
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101126/8061a91f/attachment.htm>
