[petsc-users] Passing DMMG struct.
Sean Farley sean at mcs.anl.gov
Mon Nov 22 17:27:34 CST 2010
> I made the change in the function so I now get this error
> PetscErrorCode ComputeRho(DMMG *dmmg, Vec rho)
>  DA             distA = (DA)dmmg->dm;
> In function ‘PetscErrorCode Myfunc(_n_DMMG**, _p_Vec*)’:
> error: request for member ‘dm’ in ‘* dmmg’, which is of non-class type
> ‘_n_DMMG*’
> It looks like I have a null pointer to _n_DMMG**  instead of _n_DMMG*
 It seems like your code expects you to pass a DMMG object not a DMMG*
object. There are two ways to fix this:
1) In your function 'ComputeRho' change all references of dmmg to *dmmg,
i.e.:
DA distA = (DA)(*dmmg)->dm;
2) Change your function declaration back to what you had:
PetscErrorCode ComputeRho(DMMG dmmg, Vec rho)
and then pass the object to your function as so:
ComputeRho(*dmmg, b);
Do you need your dmmg to be a pointer in your 'main' function? It looks like
your declaration could just be:
extern PetscErrorCode Myfunc(DMMG,Vec);
int main(int argc,char **argv)
  DMMG           dmmg;
...Vec b;
Myfunc(dmmg,b)
PetscErrorCode Myfunc(DMMG dmmg, Vec b)
  DA             da = (DA)dmmg->dm;
and that would fix everything.
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101122/120eefb9/attachment.htm>
