[petsc-users] Compile Errors with ifort 11.1
Tahar Amari amari at cpht.polytechnique.fr
Fri Nov 12 11:32:33 CST 2010
You are right.
Here is what I got
timac> make getincludedirs getlinklibs
-I/Data/Poub1/petsc-3.1-p5/macx/include -I/Data/Poub1/petsc-3.1-p5/include -I/Data/Poub1/petsc-3.1-p5/macx/include
-L/Data/Poub1/petsc-3.1-p5/macx/lib -L/Data/Poub1/petsc-3.1-p5/macx/lib -L/Data/Poub1/petsc-3.1-p5/macx/lib -lpetsc -L/usr/X11R6/lib -lX11 -L/Data/Poub1/petsc-3.1-p5/macx/lib -lparmetis -lmetis -lflapack -lfblas -L/Data/Poub1/petsc-3.1-p5/macx/lib -L/usr/lib/gcc/i686-apple-darwin10/4.2.1/x86_64 -L/usr/lib/i686-apple-darwin10/4.2.1 -L/opt/intel/Compiler/11.1/088/lib -L/opt/intel/Compiler/11.1/088/Frameworks/mkl/lib/em64t -L/usr/lib/gcc/i686-apple-darwin10/4.2.1 -ldl -lpmpich -lmpich -lSystem -lmpichf90 -lifport -lifcore -limf -lsvml -lipgo -lgcc_s.10.5 -lSystemStubs -lmx -lirc -lpthread -ldl -lpmpich -lmpich -lSystem -ldl
What does it mean please for me to change in my makefiles ?
Do you mean that I should remove any link other than -lpetsc ?
Great thanks
Tahar
Le 12 nov. 2010 à 18:26, Satish Balay a écrit :
> Looks like you are not using PETSc makefiles - and upgrading from
> older release to petsc-3.1
> Currently there is only one library for petsc [-lpetsc]
> Check:
> cd $PETSC_DIR
> Satish
> On Fri, 12 Nov 2010, Tahar Amari wrote:
>> Many thanks. This is solved.
>> Now at link I have the library not found. Any idea ?
>> -L/usr/local/petsc/macx/lib -lpetscsnes -lpetscvec -lpetscmat -lpetsccontrib -lpetscts -lpetscdm -lpetscksp -lpetsc -lmpich -lpmpich -lfmpich -lmpichf90 -lparmetis -lmetis -lfblas -lflapack
>> ld: library not found for -lpetscsnes
>> Tahar
>> Le 12 nov. 2010 à 18:17, Satish Balay a écrit :
>>> Looks like this is related to the following:
>>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/changes/31.html
>>> # petsc.h and petscdef.h are replaced with petscsys.h and petscsysdef.h; while petsc.h now includes ALL PETSc include files.
>>> Try removing all includes other than 'petsc.h' from your code.
>>> Satish
>>>> Hello,
>>>> While compiling one of my code with ifort , I have the following error pointing
>>>> towards petscvec.h .
>>>> Any idea about this posssible kind of error please ? Any option of ifort to use ?
>>>> Many thanks
>>>> Tahar
>>>> ifort -assume byterecl  -I/usr/local/petsc/ -I/usr/local/petsc//include -I/usr/local/petsc//include/finclude -I/usr/local/petsc//macx/include -I/usr/X11R6/include/X11 -DPETSC_HAVE_PARMETIS -DPETSC_USE_DEBUG -DPETSC_USE_LOG -DPETSC_USE_BOPT_g -DPETSC_USE_STACK -DPETSC_AVOID_MPIF_H -c petsc.fpp
>>>> /usr/local/petsc//include/finclude/petscvec.h(10): error #6418: This name has already been assigned a data type.   [NORM_1]
>>>>     integer(kind=selected_int_kind(5)) NORM_1
>>>> T. Amari
>>>> Centre de Physique Theorique
>>>> Ecole Polytechnique
>>>> 91128 Palaiseau Cedex France
>>>> tel : 33 1 69 33 42 52
>>>> fax: 33 1 69 33 49 49
>>>> email: <mailto:amari at cpht.polytechnique.fr>
>>>> URL : http://www.cpht.polytechnique.fr/cpht/amari
>> T. Amari
>> Ecole Polytechnique
T. Amari
Ecole Polytechnique
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101112/a34f4132/attachment-0001.htm>
