[petsc-users] kronecker products
Benjamin Sanderse B.Sanderse at cwi.nl
Thu Nov 4 09:43:11 CDT 2010
Hi all,
I am working on a CFD code which calculates differences, averages, interpolations, etc. by computing matrix-vector and matrix-matrix products. The basis here is formed by (very) sparse matrices and extension to more dimensions is done with kronecker products.
This works fine one a single processor; however, before implementing things in parallel I have two questions:
- is there a way to compute kronecker products efficiently in parallel with Petsc?
- if problems get big, let's say order of 10-100 million unknowns, is it still efficient to store the entire (sparse) matrices? is this commonly done, or is it better to shift to matrix-free methods? btw, the current system I can run on has several hundreds of processors and 24Gb memory per node (8 proc. per node).
Ben
