[petsc-users] about VecScatterCreate()
Thu May 27 22:07:02 CDT 2010
On Fri, May 28, 2010 at 1:02 PM, Yujie <recrusader at gmail.com> wrote:
> Dear PETSc Developers,
> I got the following information from VecScatterCreate() manpage.
> PetscErrorCode  VecScatterCreate(Vec xin,IS ix,Vec yin,IS iy,VecScatter
> *newctx)
> Collective on Vec
> Input Parameters
>        xin     - a vector that defines the shape (parallel data layout of
> the
> vector) of vectors from which we scatter
>        yin     - a vector that defines the shape (parallel data layout of
> the
> vector) of vectors to which we scatter
>        ix      - the indices of xin to scatter (if PETSC_NULL scatters all
> values)
>        iy      - the indices of yin to hold results (if PETSC_NULL fills
> entire
> vector yin)
> My question is about "ix". If xin and yin are parallel Vec, how about ix?
> Is "ix"  an IS only containing local index set or a parallel IS
> containing all the index set on all the processors (each local index
> set on its processor)? Thanks a lot.
ix contains some indices for that process. The indices can be different on
each process.
We take the union.
   Matt
> Regards,
> Yujie
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100528/aecc7fac/attachment.htm>
