[petsc-users] left and right preconditioners
hxie at umn.edu hxie at umn.edu
Sun May 23 22:06:40 CDT 2010
Thanks. That is not easy for me. I will move the right preconditioner to
the left which will lead to a similar preconditioned system with almost the
same eigenvalues. Is there any example to do the multiplicative composite
preconditioners on different preconditioner matrices from the original
matrix?
Bests,
Hui
Sun May 23 13:13:59 CDT 2010
    * Previous message: [petsc-users] left and right preconditioners
    * Messages sorted by: [ date ] [ thread ] [ subject ] [ author ]
   The PETSc Krylov methods are not coded to take directly both a left and
right preconditioner. Therefor the way to use both left and right
preconditioning together is to "fake" it by using a Mat that actually
applies right preconditioner followed by the operator followed by the left
preconditioner.
    Take a look at src/ksp/pc/impls/eisen/eisen.c and mimic that code.
(basically copy all the subroutines and in that file and modify each one to
your specific needs.)
    Barry
On May 23, 2010, at 1:01 PM, hxie at umn.edu wrote:
> Hi,
> I want to use both left and right preconditioners for a linear system.
> Both the preconditioners are based on part of the matrix. How can I
> implement it? I can construct the preconditioner matrices. Thanks.
> Bests,
> Hui
