[petsc-users] several MPIDense functions
Jed Brown jed at 59a2.org
Thu May 20 16:22:00 CDT 2010
On Thu, 20 May 2010 16:17:20 -0500, Yujie <recrusader at gmail.com> wrote:
> At least, there are "0" and "MatSetSizes" between MatConjugate and
> MatRealPart in seqdense.c;
> there are three "0" between MatConjugate and MatRealPart (why not be
> two "0") in mpidense.c?
The indexing is wrong, run in a debugger and see which function gets
called.  It won't be the one you expect (but the skew should tell you
where you are off).  Or just use petsc-3.1 which has this feature.
Jed
