[petsc-users] complex number issues
RenZhengYong renzhengyong at gmail.com
Wed May 19 13:50:50 CDT 2010
Hi,  PETSc team,
I wrote a C++ code dealing with electromagnetic problems, which can smoothly
call PETSc complied by using " --with-scalar-type=complex
--with-clanguage=cxx" .
To improve the performances of the C++ code, I changed the complex number of
type from std::complex<double> to double _Complex (C99 standard, roughly
30~50 times faster compared to std::complex<double>). But when I find that
the C99 complex number head file <complex.h> will lead to the following
kinds of errors"
/usr/include/c++/4.3/complex:57: error: expected identifier before
‘__complex__’
/usr/include/c++/4.3/complex:58: error: expected identifier before
‘__complex__’
/usr/include/c++/4.3/complex:58: error: expected unqualified-id before ‘<’
token
/usr/include/c++/4.3/complex:59: error: expected identifier before
‘__complex__’
/usr/include/c++/4.3/complex:59: error: expected unqualified-id before ‘<’
token
/usr/include/c++/4.3/complex:60: error: expected identifier before
‘__complex__’
/home/Zhengyong/packages/petsc-3.1-p1/include/petscmath.h:157: error:
expected unqualified-id before ‘__complex__’
/home/Zhengyong/packages/petsc-3.1-p1/include/petscmath.h:306: error:
‘PetscScalar’ does not name a type
/home/Zhengyong/packages/petsc-3.1-p1/include/petscmath.h:339: error:
/home/Zhengyong/packages/petsc-3.1-p1/include/petscmath.h:469: warning:
‘PetscGlobalSum’ initialized and declared ‘extern’
/home/Zhengyong/packages/petsc-3.1-p1/include/petscmath.h:469: error:
‘PetscScalar’ was not declared in this scope
expected primary-expression before ‘,’ token
expected primary-expression before ‘)’ token
initializer expression list treated as compound expression
Could you please give me some idea to deal with these problems?
Kind regards,
Zhengyong Ren
Zhengyong Ren
AUG Group, Institute of Geophysics
Department of Geosciences, ETH Zurich
NO H 47 Sonneggstrasse 5
CH-8092, Zürich, Switzerland
Tel: +41 44 633 37561
e-mail: zhengyong.ren at aug.ig.erdw.ethz.ch
Gmail: renzhengyong at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100519/0bb38c13/attachment.htm>
