[petsc-users] Change entries after MatCopy
Lisandro Dalcin dalcinl at gmail.com
Fri May 14 14:37:26 CDT 2010
On 13 May 2010 17:50,  <hxie at umn.edu> wrote:
> On May 13 2010, hxie at umn.edu wrote:
>>> On 12 May 2010 19:18,  <hxie at umn.edu> wrote:
>>>> Hi,
>>>> If I use MatCopy to get a new matrix, can i use MatSetValues to change
>>>> some
>>>> entries of that matrix and do the assemble after that? Or if I just need
>>>> to
>>>> change some diagonal entries, can I use MatDiagonalSet to change the
>>>> entries
>>>> without assembling? Thanks.
>>> Yes and Yes.
>> The first way does no work. I will try the second way.
> Sorry. I made a mistake in the variable declaration. The first way works.
> Thanks.
Next time you ask something, please make it explicit what "does not
work" actually means. Such vague statements are not helpful for any of
us in order to help people.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
