[petsc-users] Error using the same ksp with different operator sizes
Thu May 13 09:41:03 CDT 2010
On Thu, May 13, 2010 at 6:10 AM, Eloy Romero <elroal at upvnet.upv.es> wrote:
> Dear all,
> I have a code that using the same ksp, solves some matrices with different
> size in that way:
>  ierr = KSPCreate(PETSC_COMM_WORLD, &ksp);
>  ierr = KSPSetOperators(ksp, A, A, DIFFERENT_NONZERO_PATTERN);
> CHKERRQ(ierr);
>  ierr = KSPSolve(ksp, v0, v1); CHKERRQ(ierr);
>  ierr = KSPSetOperators(ksp, B, B, DIFFERENT_NONZERO_PATTERN);
> CHKERRQ(ierr);
>  ierr = KSPSolve(ksp, w0, w1); CHKERRQ(ierr);
> The KSPSolve is called with vectors of appropriated length. However I
> obtain the following error in the second call to KSPSolve:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Nonconforming object sizes!
> [0]PETSC ERROR: Mat mat,Vec x: global dim 1083 66!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 0, unknown
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./veccomp_ex2 on a linux-gnu named yah by eloy Thu May 13
> 11:27:31 2010
> [0]PETSC ERROR: Libraries linked from
> /usr/src/petsc-release-3.1/linux-gnu-c-debug/lib
> [0]PETSC ERROR: Configure run at Wed Mar 31 13:34:33 2010
> [0]PETSC ERROR: Configure options --with-blas-lapack-dir="[/usr/lib]"
> --with-clanguage=C --with-shared=0 --with-mpi=1 --with-cc=mpicc
> --with-cxx=mpicxx --download-hypre=ifneeded --with-hypre=1 --with-fc=mpif90
> --with-mumps --download-mumps=ifneeded --download-blacs=ifneeded
> --download-scalapack=ifneeded --download-parmetis=ifneeded
> --download-superlu_dist=ifneeded --with-superlu_dist --with-ml
> --download-ml=ifneeded --with-mpi-dir=/usr
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatMult() line 1889 in src/mat/interface/matrix.c
> [0]PETSC ERROR: PCApplyBAorAB() line 585 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: GMREScycle() line 161 in src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: KSPSolve_GMRES() line 241 in
> [0]PETSC ERROR: KSPSolve() line 396 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: main() line 59 in veccomp_ex2.c
> I don't find in the reference that one can or cannot use the ksp with
> matrices of different size, so I don't know if it is really a bug.
You can only use a KSP to solve one system size.
> In my application, a ksp configured by the user is given, and I would like
> to use that configuration for solving all the linear systems. Creating new
> ksps and configuring them with KSPSetFromOptions is not a complete solution
> because the user could modify the ksp by code.
You can replicate all the KSP settings in the new KSP. They are all
available by the API.
   Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100513/7ada555b/attachment.htm>
