[petsc-users] Issues with subsequent GMRES Solves
Jed Brown jed at 59A2.org
Thu May 13 09:26:25 CDT 2010
On Thu, 13 May 2010 10:20:49 -0400, "C.A.(Sandy) Mader" <mader at utias.utoronto.ca> wrote:
> I was able to get a version of the code working last night by destroying
> all of the PETSc objects between subsequent adjoint setup calls. Based
> on some of my previous results I suspect that I am having an issue with
> resetting the matrices used in the linear solve. I am running some more
> tests now to confirm this...
Try reusing all the data structures, but place a MatZeroEntries() before
your reassembly.  Perhaps the reassembly isn't setting all the same
entries, or is using ADD_VALUES?
Jed
