[petsc-users] Issues with subsequent GMRES Solves
C.A.(Sandy) Mader mader at utias.utoronto.ca
Wed May 12 13:55:36 CDT 2010
See responses in text below:
On Wed, 2010-05-12 at 13:05 -0500, Barry Smith wrote:
> Are you calling KSPSetOperators(ksp,A,B,DIFFERENT_NONZERO_PATTERN); before the second adjoint solve? Or are you trying to reuse a preconditioner from the first set of solves?
I am calling:
 call KSPSetOperators(ksp,dRdWT,dRdWPreT, &
              DIFFERENT_NONZERO_PATTERN,PETScIerr)
>    When the "second adjoint" converges and when it doesn't converge are you using the exact same matrix A, matrix B and right hand side?
As far as I know yes. For the small case (the one that works), I printed
them out and compared them and they were identical. I haven't been able
to run the same comparison for the larger case...
>    Barry
> > On Wed, 2010-05-12 at 12:48 -0500, Barry Smith wrote:
> >> Is it the same matrix or a different matrix that is solved with the "second adjoint system"?  Or is it just a different right hand side?
> > It is a different matrix. In this case I solve the CFD at a given flow
> > condition, then solve the adjoint twice (two different RHS) both
> > converge. Then I solve the CFD case for a second flow condition,
> > followed by two more adjoint solutions. Neither of which solve. However,
> > if I solver directly for the second flow condition, the adojint system
> > will solve...
> >>   If it is a different system how do you know it will even converge for the new matrix? Maybe the new matrix is much more difficult?
> > see above answer, if the same system will solve under one set of
> > conditions but not under another...
> >>   Is it possible the "second adjoint system" is singular?
> > The second system will solve if I solve it on its own.
> >>   Given that this is a very strong preconditioner the convergence for the first adjoint system is pretty poor.
> > We use an approximate preconditioner to reduce the memory requirements
> > of the solver. I do not have this problem if I use the exact matrix as
> > the preconditioner but it limits my problem size....
> >>   Does this happen also for much smaller problems? Recommend running much smaller problem to see what happens convergence wise, then run that much smaller problem with -pc_type lu to see if the direct solver handles it happily.
> > I have tried it on a smaller case and this problem does not occur...
> >> On May 12, 2010, at 12:39 PM, C.A.(Sandy) Mader wrote:
> >>> I am using PETSc to solve an adjoint system for a CFD code.
> >>> The issue I am having is that if I try to run successive cfd/adjoint
> >>> solutions, the adjoint fails to converge after the first cfd/adjoint
> >>> solution cycle. i.e.
> >>> Solve CFD (ok)
> >>> Solve adjoint system with multiple RHS's (ok)
> >>> Solve CFD at new point (ok)
> >>> Solve adjoint system at new point with multiple RHS's (GMRES iterations
> >>> stall)
> >>> PETSc is not used to solve the CFD system, only the adjoint system.
> >>> I am currently using the following solver options:
> >>> 'Adjoint solver type': 'GMRES',\
> >>> 'adjoint relative tolerance':1e-6,\
> >>> 'adjoint absolute tolerance':1e-16,\
> >>> 'adjoint max iterations': 1500,\
> >>> 'adjoint restart iteration' : 80,\
> >>> 'adjoint monitor step': 10,\
> >>> 'Preconditioner Side': 'right',\
> >>> 'Matrix Ordering': 'NestedDissection',\
> >>> 'Global Preconditioner Type': 'Additive Schwartz',\
> >>> 'Local Preconditioner Type' : 'ILU',\
> >>> 'ILU Fill Levels': 3,\
> >>> 'ASM Overlap' : 5,\
> >>> Also, I am using the fortran interface to PETSc.
> >>> As a sample, I have included two convergence histories. Both are at the
> >>> same converged CFD point(this case is ~1.2million cell so the PETSc
> >>> system is approx 6million degrees of freedom). The first is an example
> >>> where the adjoint system is solved the first time through the cycle. The
> >>> second is an example of where the adjoint is solved the second time
> >>> through the cycle:
> >>> 1) as first point in cycle
> >>> # ... KSP properties:
> >>> #       type        : gmres
> >>> #       tolerances  : rel = 1.0E-10
> >>> #                     abs = 1.0E-16
> >>> #                     div = 1.0E+05
> >>> #       max.iter.   : 1500
> >>> #       precond.type: asm
> >>> Solving ADjoint Transpose with PETSc...
> >>>  0 KSP Residual norm 0.1392E+00
> >>> 10 KSP Residual norm 0.6394E-01
> >>> 20 KSP Residual norm 0.6106E-01
> >>> 30 KSP Residual norm 0.6019E-01
> >>> 40 KSP Residual norm 0.5941E-01
> >>> 50 KSP Residual norm 0.5876E-01
> >>> 60 KSP Residual norm 0.5602E-01
> >>> 70 KSP Residual norm 0.4915E-01
> >>> 80 KSP Residual norm 0.3994E-01
> >>> 90 KSP Residual norm 0.3892E-01
> >>> 100 KSP Residual norm 0.3854E-01
> >>> 110 KSP Residual norm 0.3794E-01
> >>> 120 KSP Residual norm 0.3717E-01
> >>> 130 KSP Residual norm 0.3630E-01
> >>> 140 KSP Residual norm 0.3415E-01
> >>> 900 KSP Residual norm 0.2437E-09
> >>> 910 KSP Residual norm 0.1452E-09
> >>> 920 KSP Residual norm 0.1025E-09
> >>> 930 KSP Residual norm 0.6875E-10
> >>> 940 KSP Residual norm 0.4141E-10
> >>> 950 KSP Residual norm 0.2317E-10
> >>> 960 KSP Residual norm 0.1559E-10
> >>> Solving ADjoint Transpose with PETSc time (s) =   391.43
> >>> Norm of error = 0.1366E-10    Iterations =  965
> >>> PETSc solver converged after   965 iterations.
> >>> 2) As second point in cycle
> >>> #       type        : gmres
> >>> #                     abs = 1.0E-16
> >>> #                     div = 1.0E+05
> >>> #       max.iter.   : 1500
> >>> #       precond.type: asm
> >>> 10 KSP Residual norm 0.6400E-01
> >>> 20 KSP Residual norm 0.6140E-01
> >>> 30 KSP Residual norm 0.6060E-01
> >>> 40 KSP Residual norm 0.5995E-01
> >>> 50 KSP Residual norm 0.5974E-01
> >>> 60 KSP Residual norm 0.5971E-01
> >>> 70 KSP Residual norm 0.5957E-01
> >>> 80 KSP Residual norm 0.5906E-01
> >>> 90 KSP Residual norm 0.5906E-01
> >>> 100 KSP Residual norm 0.5906E-01
> >>> 110 KSP Residual norm 0.5903E-01
> >>> 120 KSP Residual norm 0.5901E-01
> >>> 130 KSP Residual norm 0.5901E-01
> >>> 140 KSP Residual norm 0.5901E-01
> >>> 1400 KSP Residual norm 0.5895E-01
> >>> 1410 KSP Residual norm 0.5895E-01
> >>> 1420 KSP Residual norm 0.5895E-01
> >>> 1430 KSP Residual norm 0.5895E-01
> >>> 1440 KSP Residual norm 0.5895E-01
> >>> 1450 KSP Residual norm 0.5895E-01
> >>> 1460 KSP Residual norm 0.5895E-01
> >>> 1470 KSP Residual norm 0.5895E-01
> >>> 1480 KSP Residual norm 0.5895E-01
> >>> 1490 KSP Residual norm 0.5895E-01
> >>> 1500 KSP Residual norm 0.5895E-01
> >>> Solving ADjoint Transpose with PETSc time (s) =   516.59
> >>> Norm of error = 0.5895E-01    Iterations = 1500
> >>> PETSc solver converged after  1500 iterations.
> >>> I have tried both resetting the operators between cycles and completely
> >>> destroying the KSP object between cycles. Both give the same result. Is
> >>> there a step I am missing to properly reset the system for the
> >>> subsequent solves?
> >>> Thanks in advance for your input...
> >>> Sandy
> >>> C.A.(Sandy) Mader
> >>> Ph.D Candidate
> >>> Multidisciplinary Design Optimization Laboratory
> >>> University of Toronto Institute for Aerospace Studies
