[petsc-users] Question about Fortran Kernels
Randall Mackie rlmackie862 at gmail.com
Thu May 6 13:29:32 CDT 2010
You are correct, the current version (3.1-p2) returns
--with-fortran-kernels=<bool>
Didn't realize this had changed between the older and newer versions.
Randy
On 5/6/2010 11:25 AM, Barry Smith wrote:
> On May 6, 2010, at 1:19 PM, Randall Mackie wrote:
>> I have another question about the Fortran Kernels:
>> If you do ./configure --help, it says:
>> --with-fortran-kernels=<none,generic,bgl>
>     Hmm, are you sure this is with 3.1-p2 ? Now it should print -with-fortran-kernels=<bool>  meaning 0 for off and 1 for on. Maybe the next patch has the correct message.
>> And so I've been using generic for some time.
>> After upgrading to PETSc version 3.1-p2 (or trying to upgrade), I saw
>> a message at the end of a test run that said for complex numbers,
>> I should use --with-fortran-kernels=1 for better performance.
>> But setting that to 1 was not mentioned with the --help flag, and it
>> doesn't explain what the bgl refers to either.
>     That is outdated and shouldn't be mentioned. You can use either 0 or 1.
>     Barry
>> Can someone please clarify the options with fortran kernels?
>> Thanks, Randy
