[petsc-users] Bug in DAGetGlobalIndicesF90 ?
Thu May 6 12:48:13 CDT 2010
   Switching this message to petsc-maint at mcs.anl.gov
    Does VecGetArrayF90() work correctly? Please send configure.log to petsc-maint at mcs.anl.gov
    Barry
On May 6, 2010, at 12:34 PM, Randall Mackie wrote:
> I just upgraded to version 3.1-p2, and have discovered that a call to DAGetGlobalIndicesF90 that use to work
> fine is now bombing out with the following message:
> [7]PETSC ERROR: ------------------------------------------------------------------------
> [7]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [7]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [7]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[7]PETSC ERROR: or try http://valgrind.org on GNU/
> linux and Apple Mac OS X to find memory corruption errors
> [7]PETSC ERROR: likely location of problem given in stack below
> [7]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [7]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [7]PETSC ERROR:       INSTEAD the line number of the start of the function
> [7]PETSC ERROR:       is given.
> [7]PETSC ERROR: [7] F90Array1dCreate line 52 src/sys/f90-src/f90_cwrap.c
> [7]PETSC ERROR: --------------------- Error Message ------------------------------------
> [7]PETSC ERROR: Signal received!
> Calls to DAGetGlobalIndices (the old non-F90 version) seem to work fine. The call to DAGetGlobalIndicesF90
> worked fine in the previous version I was using (3.0.0-p7).
> Can you take a look and see if you see some problem?
> Thanks, Randy Mackie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100506/e311f05c/attachment.htm>
