[petsc-users] Yet another inversion question
Sun May 2 14:10:35 CDT 2010
On May 2, 2010, at 7:13 AM, Jed Brown wrote:
> On Sat, 1 May 2010 17:00:22 -0500, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>>    This cannot be! Perhaps you used the PETSc default solver for my
>> suggestion but UMFPACK for your version? With a direct solve "all"
>> the
>> work will be in the factorization and triangular solves so if you use
>> UMFPACK for both they both do the same amount of work.
> For what it's worth, extracting a column should cost a fair amount
> less
> than doing a solve since the factored matrix will usually have a lot
> more entries.
    Perhaps. But the current get column code is terribly inefficient.
    So is the issue that MatMatSolve(A,B,X) requires TWO dense
matrices B and X, instead of just one and that is too much memory?
    Perhaps we could modify MatMatSolve(A,B,X) to allow an in-place
version (i.e. B == X) that uses only 1 or several work vectors then
you no longer have this
memory issue? Should I add this?
    Barry
> Jed
