[petsc-users] Yet another inversion question
Sat May 1 17:00:22 CDT 2010
On May 1, 2010, at 3:59 PM, Umut Tabak wrote:
> Jed Brown wrote:
>> You say that both A and B are sparse, what are you going to do with
>> the
>> product C = A^{-1} B?  The most common thing is to apply it to some
>> vectors or perhaps compute a few eigen/singular values/vectors.  You
>> rarely need an explicit representation of the product to do such
>> things.
> Dear Barry and Jed,
> Thanks for the swift replies.
> Barry,
> that goes really slower than what I tried. That is not the way to go
> I suppose.
    This cannot be! Perhaps you used the PETSc default solver for my
suggestion but UMFPACK for your version? With a direct solve "all" the
work will be in the factorization and triangular solves so if you use
UMFPACK for both they both do the same amount of work.
   Barry
> Jed,
> I have some kind of a symmetrization(or call transformation) matrix
> for symmetrizing an unsymmetric problem. I need these terms in this
> explicit symmetrization matrix. I guess this is also a rare case. I
> could not device an analytical expression to get rid of these kinds
> of terms yet. That is why I try different approaches, not with high
> expectations though.
>> It is extremely unlikely that C is symmetric.
> Yep, you are right ;)
>> This will work, you could also use the lower level interface to
>> factor
>> A, MatConvert() B to MATDENSE, then MatMatSolve() the result.
>> Internally this will do something very similar to what you have
>> already
>> done, it's questionable whether it would actually be faster (it will
>> certainly use more memory).
> I will see what this does.
> Thanks and best,
> Umut
